    Request plugin :Trilateration ruby
    14 Posts 5 Posters 3.7k Views 5 Watching
    • W
      watkins
      Dear Bep,
      You can make an equilateral triangle of known side length using the following method:
      Use the polygon tool with the number of sides set to 3
      Draw a triangle
      Double click to select all the entities and make a group
      Double click to edit the group, and when in edit mode use the tape measure tool to measure one side
      Type in the desired length
      Type yes when asked about resizing group
      Explode group
      Regards,
      Bob
      • BepB
        Bep
        @watkins said:
        Dear Bep,
        Draw a triangle
        one side
        Explode group
        Regards,
        Bob
        Thank you Bob for responding,
        But the ruby i request could help to contruct all types of triangles ,scalene if no sides are equal;isosceles if two sides are equal;equilateral if three sides are equal.
        greetings ,
        Bep van Malde
        "History is written by the winners"
        • Didier BurD
          Didier Bur
          Could some of you please make this ruby?
          On my to-do-list
          DB
          • BepB
            Bep
            On my to-do-list[/quote]
            Thank you Didier, that you are taking up an interest in developing this Ruby.
            I am very happy 😍
            I can now rest asure knowing that it will be made.
            Greetings,
            Bep van Malde
            • Didier BurD
              Didier Bur
              @Bep,
              Just a question: Given Side1 from Point A to Point B, and 2 lengthes a and b, the general trilateration case (from Al-Kashi theorem) gives 4 solutions.
              How do you would see the script determine which triangle is the "good" one (from the user point of view I mean) ?
              DB
              • GaieusG
                What if you allow all four - separately grouped - and let the user delete the unwanted ones.
                But also, what would decide which plane they are drawn? In 3D space there are endless possibilities. Or would you then restrict it to the red/green axis? Or maybe not if the initial line is drawn on any face?
                • GaieusG
                  Ah, I see, the plane has been solved. Yes, logical. Also the solution for the choice of the triangles sounds quite reasonable!
                  • Didier BurD
                    Didier Bur
                    What is currently on the drawing board is:
                    User clicks 2 points to define the first side of the triangle (the red line between the 2 "X"), and click 1 point to define the plane (the third "X"). The plane is computed with a crossproduct between vectors, this is not a problem.
                    Between the 4 possibilities still remaining, I would suggest that the first length entered would start from the start point of side 1, the second would start from end point of side 1. This leads to 2 solutions. So I also suggest that the point defining the plane will also define the pointing direction of the second side (given by the first length) to get only one solution.
                    What do you think ?
                    DB
                    • BepB
                      Bep
                      Didier,
                      You are much faster than I am.
                      I think that we come up with the same sort of solution.
                      Bep
                      possibility 1.skp
                      • Didier BurD
                        Didier Bur
                        Bep,
                        I'll PM you soon a beta for test. It's almost ready, just several weird angle problems to solve πŸŽ‰
                        Regards,
                        DB
                        • GaieusG
                          I can hardly wait! πŸ‘
