    Request plugin :Trilateration ruby
    14 Posts 5 Posters 3.7k Views 5 Watching
      remus
      You can sort of do this with the polygon tool, just set the number of sides to 3...
      If you need irregular triangles, you could then just alter it with the move tool, and with some simple maths you could have pretty much any triangle that takes your fancy.
      • BepB
        Bep
        Yes Remus i know it is possible this way and probebly some other ways ,but they are all to cumbersome doing this many-many times ,or to complicated.
        I realy would like to skip the math and let the ruby do all of that time after time.
        "History is written by the winners"
        • W
          watkins
          Dear Bep,
          You can make an equilateral triangle of known side length using the following method:
          Use the polygon tool with the number of sides set to 3
          Draw a triangle
          Double click to select all the entities and make a group
          Double click to edit the group, and when in edit mode use the tape measure tool to measure one side
          Type in the desired length
          Type yes when asked about resizing group
          Explode group
          Regards,
          Bob
          • BepB
            Bep
            @watkins said:
            Dear Bep,
            Draw a triangle
            one side
            Explode group
            Regards,
            Bob
            Thank you Bob for responding,
            But the ruby i request could help to contruct all types of triangles ,scalene if no sides are equal;isosceles if two sides are equal;equilateral if three sides are equal.
            greetings ,
            Bep van Malde
            • Didier BurD
              Didier Bur
              Could some of you please make this ruby?
              On my to-do-list
              DB
              • BepB
                Bep
                On my to-do-list[/quote]
                Thank you Didier, that you are taking up an interest in developing this Ruby.
                I am very happy 😍
                I can now rest asure knowing that it will be made.
                Greetings,
                Bep van Malde
                • Didier BurD
                  Didier Bur
                  @Bep,
                  Just a question: Given Side1 from Point A to Point B, and 2 lengthes a and b, the general trilateration case (from Al-Kashi theorem) gives 4 solutions.
                  How do you would see the script determine which triangle is the "good" one (from the user point of view I mean) ?
                  DB
                  • GaieusG
                    What if you allow all four - separately grouped - and let the user delete the unwanted ones.
                    But also, what would decide which plane they are drawn? In 3D space there are endless possibilities. Or would you then restrict it to the red/green axis? Or maybe not if the initial line is drawn on any face?
                    • GaieusG
                      Ah, I see, the plane has been solved. Yes, logical. Also the solution for the choice of the triangles sounds quite reasonable!
                      • Didier BurD
                        Didier Bur
                        What is currently on the drawing board is:
                        User clicks 2 points to define the first side of the triangle (the red line between the 2 "X"), and click 1 point to define the plane (the third "X"). The plane is computed with a crossproduct between vectors, this is not a problem.
                        Between the 4 possibilities still remaining, I would suggest that the first length entered would start from the start point of side 1, the second would start from end point of side 1. This leads to 2 solutions. So I also suggest that the point defining the plane will also define the pointing direction of the second side (given by the first length) to get only one solution.
                        What do you think ?
                        DB
                        • BepB
                          Bep
                          Didier,
                          You are much faster than I am.
                          I think that we come up with the same sort of solution.
                          Bep
                          possibility 1.skp
                          • Didier BurD
                            Didier Bur
                            Bep,
                            I'll PM you soon a beta for test. It's almost ready, just several weird angle problems to solve πŸŽ‰
                            Regards,
                            DB
                            • GaieusG
                              I can hardly wait! πŸ‘
