    [Plugin] Rotate 90 around [X, Y, Z] axis
    49 Posts 28 Posters 66.4k Views 28 Watching
    • BurkhardB
      Burkhard
      Bryce is by default " always face camera" So it is not the best choice. πŸ˜‰
      http://www.ia-plus.de
      • H
        HFM
        okay, very nice script... but could you please also make it work on X and Y axis? And make it so that you can select a shortcut for the tools?
        Tried to edit it myself but my knowledge of ruby is lacking 🀣
        [did get the 15 degrees to work though πŸ˜„ ]
          Jim
          I always wanted to make a rotator that is sensitive to the view. For example, it would rotate the selection around the axis that is closest to the axis from the camera to the target. If you wanted ro rotate around the Z, you could select the entities, go to Top view and press the shortcut. If you wanted to rotate around the Y axis, select the entities, go to the Front view and use the same shortcut.
          What do you think?
          • philemP
            philem
            @watkins said:
            Dear Philip,
            I noticed something similar when I first tried the script. I created a cube and used the script, and nothing "apparently" happened. The cube is a nice, 4-fold axially symmetric object and looks the same when rotated 90 degrees. Try something with a feature, like a notch, to make your object asymmetric about its Z-axis.
            Kind regards,
            Bob
            I didn't realise that fact about Bryce..but still no joy,
            I still can't get it to work, I have drawn an object with a notch and a cut out etc. just to be sure,(attached) I even made sure the Z axis went though the part but still can't get it to work. I have even removed the plugin, restarted Sketchup, closed it down, copied the plugin back in again still no luck.. 😞
            http://i307.photobucket.com/albums/nn310/pipp44/rotateproblem1.jpg
            Just do it, it might be fun.
            • H
              HFM
              What do you think?
              Cool, but I thought of an easier version [at least I think it's easier]
              Rotation 15 degrees on X axis under NUM1 shortcut
              Rotation 15 degrees on Y axis under NUM2 shortcut
              Rotation 15 degrees on Z axis under NUM3 shortcut
              off course all rotations are from center of the component or group
              now, tell me what do you think πŸ˜‰
              [maybe a modification of you fantastic mover? πŸ˜„ ❓ ]
              PS. Philem don't forget to create a component of your model or group it, or it won't work.
              • philemP
                philem
                What do you think?
                Hi H
                I did find that early in the piece. If its not a component it doesn't show up in the context menu..
                I even used a componen from the Component library, and it didn't work..
                Not giving up πŸ˜„
                • jujuJ
                  juju
                  ^^ huh?! o_O
                  • Didier BurD
                    Didier Bur
                    Mmmmm, this reminds me oldies but goldies "rotix.rb" "rotator.rb", the're working with arrow keys also.
                    DB
                    • daikuD
                      daiku
                      To map a context menu item to a shortcut key, you must have an appropriate item selected before you bring up the preferences window. The context menu commands will show up under "edit item". CB.
                      Clark Bremer
                      http://www.northernlightstimberframing.com
                      • daikuD
                        daiku
                        @philem said:
                        @watkins said:
                        Dear Philip,
                        Kind regards,
                        Bob
                        But the command does show up on the context menu? That's odd.
                        Clark Bremer
                        • daikuD
                          daiku
                          I have a new version ready that rotates around any of the three axes. I tried to edit my original posts to replace the ruby file, but I only succeeded in deleting the old. What's the protocol here? CB.
                          rot90.rb
                          Clark Bremer
                          • CadFatherC
                            CadFather
                            ..time we had floating shorcuts! πŸ€“
                            404 Not Found
                            (www.sketchucation.com)
                            • H
                              HFM
                              Thanx! will try the shortcut thing tomorrow ^^ [too late now 😲 πŸ‘
                              • H
                                HFM
                                whoops double post, sorry for that [as mentioned below it is late 🀣 ]
                                • tbdT
                                  tbd
                                  daiku: dont reinvent the wheel, extend it πŸ˜„
                                  here is my old 2004 script for start
                                  Rotix11 - 2004 script
                                  http://plugins.ro
                                  • philemP
                                    philem
                                    I downloaded the latest version of this ruby and it worked.
                                    thanks mate..
                                    • daikuD
                                      daiku
                                      Yes, that would have been better. I was not aware of this script. This seems to be a recurring theme. What we really need is a central repository that includes detailed descriptions of what each script does, along with detailed usage instructions. There are several collections around, including on this forum, but nothing that does a complete job. I realize this would be a huge undertaking for someone, but whoever steps up would certainly earn "hero" status in our community.
                                      Clark Bremer
                                      • T
                                        tor
                                        Many thanks for this simple, yet very useful plugin... exactly what I was looking for when creating some configurations of modular components.
                                        What I think would be really keen is to be able to call this script as one is placing a component from the component browser. Any ideas on how to make that work?
                                        Tor
                                        • daikuD
                                          daiku
                                          Not sure what you mean. Do you want to rotate EVERY time you place it? Just re-create the component with the correct orientation to the local axes. CB.
                                          Clark Bremer
                                          • T
                                            tor
                                            Well, what I was hoping for is to select a component from the component browser to place into the model, then as it is moving with the mouse at the insertion point, rotate it, so that it's in the correct orientation. Kind of a building block assembly system. And, sometimes a component would need to be rotated, sometimes not.
                                            Obviously, I can put the component "down", rotate, then move it, but was just hoping to simplify that process in the creation of numerous modular assemblies.
                                            But it seems that the component being placed is not actually selected, per se, so no shortcut key works on it.
                                            Tor
                                            • 2 / 3
