    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 528.7k Views 153 Watching
      REGIS
      Thanks remus
      I understand : Whaat is Dale Marten.
      I know this plugin and perhaps it's the best plugin with FFD i've never seen before.
      Unfortunately I've no cash to buy it at the moment.
      Perhaps Cphillips can make a subdivide plugin if he wants.
      Regards
        remus
        There is a subdivide aspect to the current version of FFD, although it differs from whaats subd, it probably doesn't make much/any difference when your using it for FFD stuff, though.
          REGIS
          Yes remus, I had made a try but the result isn't what I want to have, see the skp file attached some post before.
          I don't know the result of whaat's subdivide plugin.
            remus
            Heres what i got after putting a similar shape through whaats subd:
            http://farm4.static.flickr.com/3232/2481919278_dee1dbabc3_o.jpg
            not very good either really, i did get better results on more regular shapes, though.
              CPhillips
              Regis, I wouldn't know how to do that. Its different from the very simple subdivision I do here.
              I don't want to confuse this with Whaats cool plugin. Ill probably rename it something like "Dice"
                REGIS
                OK CPhillips
                Is there a way to have a subdive face like the subdivide tool native sketchup (for a straight line) without to have to subdivide two lines and draw lines to create new faces. ❓
                Perhaps we can create a new topic to discuss that ❓
                regards
                  CPhillips
                  @regis said:
                  OK CPhillips
                  regards
                  I don't really know anything about subdividing faces. This just slices the mesh.
                  Doesn't Whaats plugin do what you describe?
                    remus
                    From my very cursory experiments, it seems whaats version of subd does what regis describes, but also subdivides the geometry between the vertices.
                    http://farm4.static.flickr.com/3040/2485814152_4a6396b354_o.jpg
                      REGIS
                      On simple shapes it's ok but on more complex it's not the same.
                      It seems to do triangulate faces on coplanar quadrangulate faces
                      FFD subdivide option is great on cube with square angle because he cuts the cube on RGB axes.
                      For those how know blender there is an option in the k key : select a face an select loop cut.
                      I would like to have the same option in sketchup.
                        justry
                        What Dale's plugin does is called a catmull-clark subdivision. Google it and you'll find lots of pages explaining the algorithm. It's not that hard to understand once you've went through it a couple of times.
                        • O Offline
                          oecodesignator
                          Hello Chris.
                          Applications? Last night, I was talking to our design manager and he was looking for a capability to add quickly in my landscape architecture model a twisted (literally, not the sicko type, hehe) building. I failed to get a copy of the script previously but read Catch Up had previously enough to know it could be done. I'm downloading the script and at the same time posting this to say, "Yes, UAE has been waiting for a script like this to keep the rapid-paced development moving. Cheers!"
                          and thanks.
                          Rico
                          @cphillips said:
                          Has anyone actually used this script for anything useful yet?
                          Ain't it a grrrreat day!
                          RICO
                            CPhillips
                            Thanks Rico!
                              mikaztro
                              Where can I download the latest FDD plugin. Thanks.
                                See Chris' post when he updated the link:
                                http://www.sketchucation.com/forums/scf/viewtopic.php?p=60071#p60071
                                  mikaztro
                                  Thanks mate!
                                    pav_3j
                                    this is brill, thank you so much
                                    pav
                                    Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                      svetik
                                      Thanks man-it is really inportant emproovement for SU. Google is too poor to do it 😃
                                      BUT! it does not work for my favorit 3D soft- AtLast Sketch Up 5 😢 Why?
                                        remus
                                        This is a bit of a long shot (aka a feature request) but would it be possible to make it so that grouped geometry (within the group to be FFDd) could be moved by the control points but not deformed. In an ideal world the edges that were 'shared' between the group and the geometry outside the group would also remain unaffected.
                                        I was just thinking that if this worked you could use FFD a a very basic method for manipulating rigged meshes, perhaps in combination with monsterzeros rigging hack.
                                          CPhillips
                                          I dont think I follow. Can you post a picture?
                                            CPhillips
                                            I think it should. But I dont have SU5. Can you open the ruby console try it and see if it prints any errors?
                                            • 20
                                            • 21
                                            • 7 / 21
