    3D Rendering
    7 Posts 2 Posters 1.5k Views 2 Watching
    • T
      twharvey
      Hi all,
      I'm interested in the references to 3 dimentional rendering. Is there a tut or discussion somplace that explains this trick?
      My work-around is time consuming: I build the object, smooth it then make the top, front, back and two sides into groups and render them one-at-a-time. Afterwards I explode the whole thing and then make it into a new group or component. This avoids the "funny, streaked side business" but it's a lot of work.
      Tom
      PS with my new Subdivide & Smooth, the stones are coming along nicely.
      Tom
        remus
        When you say 3D rendering do you mean as in real-time rendering of the sort that would let you orbit around a model while its being rendered?
        If this is the sort of thing you mean id recomend having a look at the lightup plugin (see the ruby forum), its more of a lighting simulator, rather than a fully blown render engine but it could work depending on what sort fo detail you want.
        Apart from that i think your best bet would be game engines, although i know very little about them i tihnk they could probably do what you want. Places to start looking are probably the cryengine and the UT engine (i cant remeber what its called.)
        • T
          twharvey
          Hi Remus,
          I don' think it's that sophisticated. Solo (pete) sometimes talks about projecting textures from three sides (I think) at once, thus avoiding the streaky sides you get from rendering a 3d object from one side only.
          Tom
          Tom
            remus
            Yeah, thats a bit simpler to do πŸ˜› i'll do a quick tut...
            • T
              twharvey
              Cheers, Remus
              Tom
                remus
                Here you go, sorry it's os rough, i havent got the patience for good tuts.
                projected texture tut.skp
                • T
                  twharvey
                  Thanks, Remus. That was very clear.
                  Tom
                  Tom
