    šŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Question
    extensions
    14 Posts 4 Posters 2.2k Views 4 Watching
      tomislavm
      I am sending you 2 pictures, one from sketchup and another from PDF.
      Question, why in PDF can not see dimensions?
      • Al HartA Offline
        Al Hart
        RPS 3D PDF uses an adobe 3D features - U3D.
        We are able to place 3D faces into U3D, but have not been able to figure out how to place text and dimensioning.
        Al Hart
        IRender nXt from Render Plus
          tomislavm
          Thank You!
          Do You have the same problem?
          • Al HartA Offline
            Al Hart
            Yes - we are not able to place text or dimensioning.
            For just a little labeling, you could place 3D text in the SketchUp model.
            You could also place 3D text in the model like (#1) and have #1 refer to notes in the body of the PDF document.
            Al Hart
            • soloS Offline
              I use Deep exploration for my 3D pdf's, however the same issue exists so I have started using arrow lables as shown below.
              The SU model
              http://img367.imageshack.us/img367/7291/suimagebp6.jpg
              The 3D pdf result
              http://img291.imageshack.us/img291/2254/pdfimageae8.jpg
              Not quite the desired result, but works pretty well.
              • Al HartA Offline
                Al Hart
                Are arrow labels a SKP feature, or do you just make them?
                The RpTools "text / sign" feature is similar - it takes RTF text and places it as an image or on a sign component, but the arrow idea is a good one.
                Al Hart
                • soloS Offline
                  The arrows and caption planes I made in SU and now have a whole folder of different shapes for different display needs. I use PSP to make my labels (very quick actually) and apply them to the designated text face on the shape as a texture.
                  I attached the one from sample above.
                  tetx arrow.skp
                  • Al HartA Offline
                    Al Hart
                    PSP ?
                    Al Hart
                    • soloS Offline
                      Paintshop pro
                      • Al HartA Offline
                        Al Hart
                        Ah yes.
                        Our SketchUp tool lets you create text with colors and formatting, and save in on a SketchUp image for placement in a drawing.
                        I mention this for any other users who may be reading this thread, rather than the power users, because once you learn how to do this quickly with paintshop, and import, you don't need a special SketchUp tool. However, new users sometimes appreciate a "dont have to leave SketchUp" tool.
                        I guess one other advantage of the RpTools tool is that you can right click on the sign in SketchUp, reload and edit the text, and update the sign. (We save the .RTF format for the text on the SketchUp entity.)
                        At any rate, I hope you don't mind if we "borrow" your idea, and add an arrow option to our Sign tool to make pointers...
                        Al Hart
                          GUNAWAN W
                          hi everyone,
                          @tomislavm
                          why not use exported jpg images than convert it to PDF file?
                          i found this:
                          I've finally figured it out: you have to also make sure that you're in hidden line mode. shading will throw off the scale when exporting to pfd. in hidden line, works like a charm. surprised no one mentioned this as a possible solution.
                          301 Moved Permanently
                          (www.sketchucation.com)
                            tomislavm
                            Thank you everyone for sugestions but I stil dont understand why it can not be seen in PDF.
                            • Al HartA Offline
                              Al Hart
                              RPS 3D PDF can display faces and images but cannot display text and dimensioning.
                              You will have to place you text and dimensioning as "images" in the 3D PDF in order to be able to see them.
                              Al Hart
                                tomislavm
                                O.K. I will try!
