    Polyreducer Experiments
    43 Posts 27 Posters 11.8k Views 27 Watching
      remus
      a4chitect: http://www.sketchucation.com/forums/scf/viewforum.php?f=253
      πŸ˜†
      • W
        watkins
        Dear ErikB,
        There is no need to reverse the process. Just save the component in its high poly form outside the model, use the poly-reducing script inside the model to speed up modelling, then re-load the high poly version before rendering. Sometimes, native Sketchup has the just the tools you need.
        Kind regards,
        Bob
          remus
          You could even just place the high poly components on another layer and have some dummy components on a layer and jsut switch between them for low poly/high poly.
          • T
            Teezer
            Wow, that's quite impressive! 😲 I'll certainly buy a copy... πŸŽ‰
            Real life is just another website, albeit a rather boring one.
            • soloS
              Awesome addition to your arsenal of must have plugins, well done mate.
              • chippwaltersC
                chippwalters
                Geez Dale-- prolific is the word which comes to mind. Great stuff!
                Currently working with Cross-Reality technologies
                • Mike LuceyM
                  Mike Lucey
                  Hi Dale, Well done! This will be a very useful plug-in.
                  Just a thought! Most of the time when I use a poly reducer
                  program, its because the model is so large that I have trouble
                  bringing it into SU in the first place.
                  Mike
                  • L
                    linea
                    Ah good point Mike
                    • BurkhardB
                      Burkhard
                      I dreamt about a poly reducer that reduced by a slider, like an undo - redo function.
                      So I can place high poly objects into my scene, reduce them for the workflow and redo it by fixed renderscene - instead of replacing 😍 ....but it's just a dream 😳
                      http://www.ia-plus.de
                      • K
                        kwistenbiebel
                        Hi Dale (Whaat),
                        I love this idea of a SU polyreducer.
                        Some thoughts about this from a user perspective:
                        1. Is it possible to have the plugin both as a standalone as being an add-on to Subsmooth?
                          That would reduce the amount of plugins in my menus...
                        2. It would be great if the polyreducer could be combined with a proxy/instancing system so the low poly version can be used as proxy for high poly components.(The one in skindigo is a great start for that..). I am not sure if it is possible to make a 'universal renderable' proxy/instancing system no matter which render engine is used.
                        3. It would be great if we could 'context click' (=right click) to use the commands of your plugins. I kind of miss this in the subsmooth plugin. (I know I can assign a key to a command but still...πŸ˜‰)
                        Cheers and good luck with the plugin. Looking good so far.
                        Kwistenbiebel.
                        • W
                          Whaat
                          @pixero said:
                          Looks interesting. What about keeping UVs for correct texturing?
                          I can maintain material assignment but I don't think it will be possible to keep the UVs looking right. We'll see...
                          • B
                            Bryden
                            Looks like a great plugin πŸ‘ This is better than remodeling a low polygon version of a model ive made. I will have many uses for this. 😍
                            http://img7.imageshack.us/img7/8487/googlesketchupuserbarzh3.jpg
                            • G
                              GUNAWAN W
                              so this a teast after smooth&subdive πŸ˜†
                              πŸ‘ πŸ‘ πŸ‘
                              • boofredlayB
                                boofredlay
                                Excellent. I look forward to this one.
                                • H
                                  huyvuvn
                                  wonderful 😍 😍 😍
                                  happiness on the way, not in the destination.
                                  • mariochaM
                                    mariocha
                                    Yeah great work !! Subdivide & Smooth is really a winer.
                                    Can't wait to try Polyreducer.
                                    euh,... the plugin is not out yet, right?
                                    Cause I can't find it.
                                    %(#008000)[Mario C.
                                      remus
                                      No, its not out yet, hopefully its only a matter of time though.
                                        anbanhtratien
                                        😍 oh yessssssss.........very good...........thanks 😍 πŸ‘
                                        • RayOchoaR
                                          RayOchoa
                                          You could make it an addition to subdivde and smooth. That would be really good. 😎
                                          CaR DeSiGnS bY mE
                                          http://ray-ochoa.com
                                          • W
                                            Whaat
                                            Sure...but then you'd have to purchase subD and smooth twice if you already had it... πŸ˜‰
                                            • 2 / 3
