    How do i do good renders
    extensions
    13 Posts 6 Posters 2.5k Views 6 Watching
    • Jean-FrancoJ Offline
      Jean-Franco
      Hi, + Solo πŸ‘
      Jean-Franco
      • FrederikF Offline
        Frederik
        Read what Solo just wrote - and then read it again, cause it's all there... πŸ˜‰
        Cheers
        Kim Frederik
          pav_3j
          firstly,m spot on solo.
          secondly, it does take time to get good for sure (i'm still at a very basic level)
          i think to key is to not run before you can walk.
          test every setting on your renderer out, using a few models, and i mean EVERY setting, that way you will learn all the features.
          i think that remus has been doing this? correct me if i am wrong.
          trial and error, that is the key.
          oh and also, if there is a term you don't understand, then look it up straight away.
          i started my own little glossary in a word document, with the name of the term, a quick description, and (most importantly) a link to where i got the imformation for my future reference.
          hope this was helpful.
          now go give it a go!
          pav
          Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
            remus
            Indeed pav, thats basically what i do, and its pretty good fun, althouigh yiu do tend to get in some pickles.
            The only thing i can really add is to every now and then set yourself a target, like learn to use a certain feature, this way you'll get a really good understanding of soem features.
            oh, and have fun.
            • FrederikF Offline
              Frederik
              @Pav and remus
              http://www.kerkythea.net//users/Frederik/Anim-Icons/applause.gif
              Allow me to highlight...
              Although it's not complete, the new Getting Started tutorial have a Glossary on the last 6 pages... πŸ˜‰
              @remus said:
              ...every now and then set yourself a target, like learn to use a certain feature, this way you'll get a really good understanding of soem features.
              oh, and have fun.
              Personally I believe that the above applies for all render applications - not only Kerkythea... πŸ˜‰
              So... Enjoy and have lots of fun... πŸ˜„
              Cheers
              Kim Frederik
              • RayOchoaR Offline
                RayOchoa
                Thanks for your advice. Im currently rendering this car and i wanted to know how i could make it so that the texture wouldn't be squared on each triangle.
                CaR DeSiGnS bY mE
                http://ray-ochoa.com
                • FrederikF Offline
                  Frederik
                  This is a UV-mapping issue and have nothing to do with KT... πŸ˜‰
                  If you haven't done it already, I suggest that you download the new Getting Started tutorial and see page 22... πŸ˜‰
                  If this doesn't help, you'll need to apply a texture in SU (a color without a texture won't help you - it needs to be a texture) in order to be able to apply the material in KT...
                  Also - it seem that you've rendered this using one of the Ray Tracing presets...
                  Please try to render using one of the presets above no. 3... πŸ˜‰
                  Hope this will help you further... πŸ˜„
                  Cheers
                  Kim Frederik
                  • RayOchoaR Offline
                    RayOchoa
                    Thx that helped alot. I put Projected on the material in sketchup but it leaves strange lines on the sides. Is this normal?
                    CaR DeSiGnS bY mE
                      remus
                      Yes, it is normal, its cause by the material being 'stretched' over the side of the maodel. You can minimise the effect by dividng the model in to lots of flat faces and then projecting a texture straight on to the face.
                      • RayOchoaR Offline
                        RayOchoa
                        @remus thanks for your help. I had to ask, what is the difference between the render presets?
                        CaR DeSiGnS bY mE
                        • FrederikF Offline
                          Frederik
                          Please download the new Getting Started tutorial and read page 33 and 34...
                          Also - I would recommend that you visit the KT Forum where you can make a search for these and similar questions and find a lot of good answers... πŸ˜‰
                          Cheers
                          Kim Frederik
