    Net bridge, issue on semi transparend rendering
    12 Posts 4 Posters 1.8k Views 4 Watching
    • F Offline
      fidudjan
      I try to model a net bridge over a lagooning zone (marsh), something like this pict1) net-bridge.jpg
      Until now I got a middle succes (at my level) using the wonderful skin plugin and a wire fence material. pict 2)filets.jpg
      However the rendering with podium does not take into account the semi transparency of this material filet-rendering.jpg.
      Any clue ? (or improvement suggestions)
      Fred
      • tinanneT Offline
        tinanne
        Three things....
        1. Is the net a front face or back face? And is it grouped? I beleive, in Podium, you have to apply the texture to the actual face, not the group, and it should be a front face.
        2. Scale your "net" texture smaller.
        3. Cool project!
        Executive Director : American Society of Architectural Illustrators
        AIP 30 Competition opens soon. ASAI.org
        Architectural Rendering
          I don't know if Podium can interpret alpha transparency. In most rendering apps you use clipmasks for something like that (although the latest Kerkythea can use alpha masks but it needs to be manually checked - maybe it has always been there I'd just never noticed).
          • tinanneT Offline
            tinanne
            i think it can... I did a pool rendering using Podium and the water was semi-transparent. Wouldn't that be the same thing?
            • F Offline
              fidudjan
              Thanks for your advices.
              I did a try to set the material on each individual face (skin does creates a component) but it did not change.
              The only way I can get transparency with podium is to use a semi transparent material (transparency set within SU). Otherwise with material that have png transparency but that are not set transparent in SU, it seems that it does not work.
              I guess that correspond to what Gaieus was telling (but I am not familiar with graphical formats)
              Fred
                A clipmap is a regular raster image (say jpg) that has only black and white "colours" in it. You apply it over the diffuse image (the "real" material) in rendwering engines. Anything that is white will be visible and what is black will be transparent.
                Now since I don't use Podium, I don't know how (or whether) you can apply clipmasks. Hpefully Pete (solo) will chhime in - he's a master of Podium (I'll PM him).
                • soloS Offline
                  Frederick, I sent you a PM.
                    And now wi'll never know the solution?! πŸ˜’
                    • soloS Offline
                      LOL, for those that need to understand clip-maps here is a quick tutorial.
                      http://www.websitetoolbox.com/tool/post/supodiumforum/vpost?id=2442506
                      I PM'ed Frederick so that he could upload the model and not need tho share it on open forum.
                        Yeah, I've seen that (believe or not I often lurk around the Podium forums πŸ˜„ )
                        Thanks for linking it!
                        • soloS Offline
                          Is this in line of what you require?
                          If yes I will send you the diffuse and clips.
                          http://img148.imageshack.us/img148/2858/200805011753565m43syz8.jpg
                          • F Offline
                            fidudjan
                            Definitely it is !!!
                            Thanks a lot. I will now read the tutorial you did mention.
                            (but I am not really found of the 3D guy ! πŸ’š it is for shadow test I guess )
