    Lighting Plugin for Sketchup
    232 Posts 67 Posters 85.2k Views 67 Watching
      pmiller
      For all those who are unable to unzip* the file (blocked), is there any chance of a new zip file?
      *despite using properties to unblock. BTY this zip file is the first I have ever encountered that will not unzip.
      • EdsonE Offline
        Edson
        @efrado said:
        :? I reproduced the steps shown in the video tutorial but what I get is a white screen.
        what I am doing Wrong?
        have you tried reversing faces?
        http://www.mahfuz.arq.br
        • E Offline
          Efrado
          Hi Edson,Yes I always check that,
          I wonder if it could be a graphic processor problem?
          I use a tablet PC with GP Intel(R)
          thanks
          • I Offline
            ilay7k
            Is it possible (or can you make it) so that we could export the model with baked lighting?
            i want too to ask...i remember some technics from skindigo by Dale Martens (aka Whaat and thanks a'lot for it): exporting of photo matched picture...Can we use sample preset to do it?
            • AdamBA Offline
              AdamB
              thanks
              Might be. You could try Tools->LightUp->Force Simple Rendering, then restart to pick up the change.
              Adam
              • AdamBA Offline
                AdamB
                LightUp only draws front faces so Edson is right, checking your faces are the correct way and/or fly around the model to check they're not facing the opposite way you expected!
                You might also set a non-white background to be sure its not white materials on a white background rather than not drawing anything.
                Although they will be fixed, right now LightUp has problems with:
                • groups of groups
                • components inside components
                • Instance/Group materials
                • Highly tessellated geometry.
                Adam
                • AdamBA Offline
                  AdamB
                  Yes, mail "help at light-up.co.uk" with your reg details and I'll flip some bits.
                  [FWIW Its just a regular zipfile. No, really it is!]
                  Adam
                  • jujuJ Offline
                    juju
                    on knees, praying
                    Please have them sort out what they need to so it can get to market.
                    done praying
                    • AdamBA Offline
                      AdamB
                      on knees, praying
                      done praying
                      We've had a ton of feedback in this one week. Its been really useful - and LightUp needs to address those issues. The fact of the matter is that most people really don't care about the rendering detail - they just want something that improves the speed of their workflow and the range of their visualisation options. I'll have to put my hand up and admit I was surprised by how strong that sentiment is.
                      Where we're up to right now is focussing on nailing these crash bugs, simplifying the UI because many reported finding the Ambient Occlusion/Direct Lighting/Tourtool buttons confusing, improving performance generally and closing out useability issues like groups, group materials etc.
                      So, models that cause reproducible hangs/crashes/slowness are like gold for helping in these tasks. Hint, hint!
                      Adam
                      BTW The first pass at simplification of GUI got committed this morning. Basically you specify Lighting in Preferences and then hit Tour and it does what it needs to do. So now only 3 buttons: Preferences, Query and Tour.
                      • EdsonE Offline
                        Edson
                        adam,
                        what do you mean by not caring about the rendering detail? what rendering detail? could you elaborate a little bit on that?
                        i am not sure this helps you to understand the above but people like me --very interested in rendering but knowing very little about it-- do not really know exactly what LightUp can do for us.
                        i must confess i do not understand fully what LU can do for me. can it help me with my exteriors scenes? yes? please show me how. what about interiors? let me see more examples. and so on. this is why i have been asking for more videos and tutorials.
                        i hope this is useful feedback for you.
                        • I Offline
                          ilay7k
                          Hello Edson, i think it's shadow helper, then you can use any render solution with minimal lighting options if will use LU maps. And it's "simple" RT-engine, any-way for end-work need Pshp skills...for example look at some work of hypershot from bunkspeed
                          • E Offline
                            Efrado
                            Thanks Adam for your guidance,but looks like a have to replace mi machine.
                            I downloaded your attach and this is the way it appears
                            studio21.skp
                            • E Offline
                              Efrado
                              I do not if you get the same image that I did in my computer ,I mean,I only saw the plain drawing without illumination
                              • AdamBA Offline
                                AdamB
                                Thanks for the model. Sounds like a bug I need to look into and fix.
                                Cheers,
                                Adam
                                • AdamBA Offline
                                  AdamB
                                  @edson said:
                                  adam,
                                  So, what I'm saying is that based on the feedback I've got, most are concerned with "accessibility" of the technology, and not the low level "tweakability" of the technology. I think this is borne out by Podium's popularity and on the flipside things like Sunflow which is a great renderer but not very user-friendly wrt SU - thus largely ignored.
                                  [/quote]
                                  All feedback is useful, Edson. And I really appreciate you taking the time. Sure LightUp can do exterior scenes. I will upload a video RSN. I've found some some graphics card incompatibilities in the demo subsequently that may trip you up. But hopefully not. And LightUp is also useful from a straight touring large worlds pov because its rendering is very significantly faster than the straight SU rendering (which has to deal with lots of stuff LightUp can ignore).
                                  Adam
                                  • E Offline
                                    Efrado
                                    Hi Adam,I just removed the LU from mi computer.
                                    Is it a problem if I try to reload LU,using the authorization key you send initially?
                                    Thanks.
                                    • I Offline
                                      ilay7k
                                      If you add one to all features of LU like light analysis(in future, su2rad), it will be great
                                      • JClementsJ Offline
                                        JClements
                                        About not being able to unpack the zip file.
                                        As far as I can tell the problem exists with the built-in XP windows zip utility, simple as that.
                                        As soon as I downloaded one of the free unzip utilities the file unziped just fine (I used ZipCentral).
                                          REGIS
                                          Hi AdamB
                                          I have this problem with LU when I apply a texture in my model.
                                          An idea ?
                                          Cheers
                                          • AdamBA Offline
                                            AdamB
                                            @regis said:
                                            Hi AdamB
                                            [attachment=0:3i8h6f6m]<!-- ia0 -->pb LU.jpg<!-- ia0 -->[/attachment:3i8h6f6m]
                                            An idea ?
                                            Cheers
                                            Its a bug in the demo. (TBD came across it earlier too). Easiest solution is to regenerate the lighting by making a small change to the model (eg add a single line) that will cause LightUp to regenerate everything.
                                            Adam
                                            • 11
                                            • 12
                                            • 10 / 12
