    What's your bevelling solution?
    9 Posts 7 Posters 679 Views 7 Watching
    • StinkieS Offline
      Stinkie
      As we all know, SU doesn't have a bevelling tool. Now, I'm wondering how y'all overcome that. Do you take your SU models into other apps? If so, what's your workflow?
        remus
        i just dont bother most of the time. I should stop being so lazy really.
          Jon
          If it's really important, I usually just do it by hand (follow-me).
          But, most of my models (now) only get modeled to be rendered, in which case I use Kerkythea's beveling.
          Jon
          KT Team member
          • StinkieS Offline
            Stinkie
            Well ... I've resorted to bevelling by hand, using FollowMe and, in some cases, AutoFold. Works fine, but it's a fairly time consuming process. Nevertheless, I can't do without bevels. Either that's true, or I'm just picky. πŸ˜„
            I wanted to go to church tomorrow, but I can't. πŸ’š More bevelling to do. But hey, laborare est orare. πŸ’š
              Jim
              Is this what you need?
              (www.smustard.com)
              • StinkieS Offline
                Stinkie
                Thanks, Jim. Already tried that one. Doesn't have any real advantage over bevelling by hand, IMO.
                (Whaat pointed out some time ago he thinks SU 7 will have a bevelling tool. I think he's right. The Google boys aren't dumb - I'm sure they're aware of what people would like to see added to SU.)
                • Alan FraserA Offline
                  Alan Fraser
                  Here's a couple of ideas for approaching bevels from a different angle. Sometimes faster than Follow Me, sometimes not...it depends on what you are doing.
                  I use the smoothing break quite extensively; it helps keep flat faces with rounded edges looking flat instead of somewhat pneumatic.
                  bevel cheats.skp
                  3D Figures
                  • Mike LuceyM Offline
                    Mike Lucey
                    Simply, yet effective. Thanks Alan.
                    • marked001M Offline
                      marked001
                      awesome, alan! i cant wait to try this πŸ˜„
                      http://www.revision21vis.com
                      instagram: revi21on
