    Lighting Plugin for Sketchup
    232 Posts 67 Posters 58.9k Views 67 Watching
    • EdsonE Offline
      Edson
      adam,
      thank you for your patience. fake emitters understood. i went back to the skippy and played some with it.
      as for the Irradiance Cache, understood in theory . i have yet to see it in action to fully grasp the idea.
      regards.
      http://www.mahfuz.arq.br
      • AdamBA Offline
        AdamB
        @efrado said:
        PLEASE HELP!
        I just registered trying to downloud this MARVELOUS plugin from AdamB,but unfortunately the compressed file does not appear.what do I must do? 😲
        1. After you've registered an email is sent to you.
        2. You need to click on the link in the email LightUp sent to activate your registration.
        3. You then login and go to the download page to download the demo.
        Adam
        • AdamBA Offline
          AdamB
          @edson said:
          adam,
          regards.
          I'm planning a video tutorial very soon.
          Adam
          • PixeroP Offline
            Pixero
            Is it possible (or can you make it) so that we could export the model with baked lighting?
            • E Offline
              Efrado
              😍 😄 Thanks ADAM for this your astounding work
              which promises to be an incomparable and fast tool for rendering the SU projects.
              I am going to start studing the documentation.
              By the way did you find the corkscrew? Ihope so. Drink a big sip for me 👍
              • david_hD Offline
                david_h
                Thanks Adam. I just got my DEMO and docs. Anxious to play with it. Congrats! 😍
                  REGIS
                  Hi Adam and thanks for your plugin.
                  I'm playing with light up now but I don't find the point light component in the component's window.
                  Where is it gone ❓
                  Thanks.
                  • EdsonE Offline
                    Edson
                    Where is it gone ❓
                    Thanks.
                    it is there, but one does not see it. click on the white space.
                      REGIS
                      Thanks Edson it's OK. 👍
                      • E Offline
                        Efrado
                        😕 I reproduced the steps shown in the video tutorial but what I get is a white screen.
                        what I am doing Wrong?
                          pmiller
                          For all those who are unable to unzip* the file (blocked), is there any chance of a new zip file?
                          *despite using properties to unblock. BTY this zip file is the first I have ever encountered that will not unzip.
                          • EdsonE Offline
                            Edson
                            @efrado said:
                            :? I reproduced the steps shown in the video tutorial but what I get is a white screen.
                            have you tried reversing faces?
                            • E Offline
                              Efrado
                              Hi Edson,Yes I always check that,
                              I wonder if it could be a graphic processor problem?
                              I use a tablet PC with GP Intel(R)
                              thanks
                              • I Offline
                                ilay7k
                                i want too to ask...i remember some technics from skindigo by Dale Martens (aka Whaat and thanks a'lot for it): exporting of photo matched picture...Can we use sample preset to do it?
                                • AdamBA Offline
                                  AdamB
                                  thanks
                                  Might be. You could try Tools->LightUp->Force Simple Rendering, then restart to pick up the change.
                                  Adam
                                  • AdamBA Offline
                                    AdamB
                                    LightUp only draws front faces so Edson is right, checking your faces are the correct way and/or fly around the model to check they're not facing the opposite way you expected!
                                    You might also set a non-white background to be sure its not white materials on a white background rather than not drawing anything.
                                    Although they will be fixed, right now LightUp has problems with:
                                    • groups of groups
                                    • components inside components
                                    • Instance/Group materials
                                    • Highly tessellated geometry.
                                    Adam
                                    • AdamBA Offline
                                      AdamB
                                      Yes, mail "help at light-up.co.uk" with your reg details and I'll flip some bits.
                                      [FWIW Its just a regular zipfile. No, really it is!]
                                      Adam
                                      • jujuJ Offline
                                        juju
                                        on knees, praying
                                        Please have them sort out what they need to so it can get to market.
                                        done praying
                                        • AdamBA Offline
                                          AdamB
                                          on knees, praying
                                          done praying
                                          We've had a ton of feedback in this one week. Its been really useful - and LightUp needs to address those issues. The fact of the matter is that most people really don't care about the rendering detail - they just want something that improves the speed of their workflow and the range of their visualisation options. I'll have to put my hand up and admit I was surprised by how strong that sentiment is.
                                          Where we're up to right now is focussing on nailing these crash bugs, simplifying the UI because many reported finding the Ambient Occlusion/Direct Lighting/Tourtool buttons confusing, improving performance generally and closing out useability issues like groups, group materials etc.
                                          So, models that cause reproducible hangs/crashes/slowness are like gold for helping in these tasks. Hint, hint!
                                          Adam
                                          BTW The first pass at simplification of GUI got committed this morning. Basically you specify Lighting in Preferences and then hit Tour and it does what it needs to do. So now only 3 buttons: Preferences, Query and Tour.
                                          • EdsonE Offline
                                            Edson
                                            adam,
                                            what do you mean by not caring about the rendering detail? what rendering detail? could you elaborate a little bit on that?
                                            i am not sure this helps you to understand the above but people like me --very interested in rendering but knowing very little about it-- do not really know exactly what LightUp can do for us.
                                            i must confess i do not understand fully what LU can do for me. can it help me with my exteriors scenes? yes? please show me how. what about interiors? let me see more examples. and so on. this is why i have been asking for more videos and tutorials.
                                            i hope this is useful feedback for you.
                                            • 11
                                            • 12
                                            • 1 / 12
