    Half Rendered Print
    2 Posts 2 Posters 482 Views 2 Watching
    • T
      triciad333
      Whenever I try to print to pdf it only renders half the image. It leaves a wire frame from around the horizon down.
      Thanks,
      Tricia
      • L
        LarryV
        Check to see if you have any section planes which might be causing this. Look in the toolbar for the section plane tool. if you enable it and you see section planes that you did not intend, right click on them to delete them.
