    Error msg help please!
    3 Posts 2 Posters 1.6k Views 2 Watching
    • L
      lapx
      I'm getting this error message. "...Missing some 2d grpahic exporters." I'm trying to export to autocad. Can anyone help here? Is there a way to solve this other than to reinsatll and loose my custom settings?
      Thanks,
      • R
        richcat
        Hi lapx
        I had exactly the same problem,, but only discovered it when exporting jegs etc. to test max export size. It also got worse and worse the more I tried to export, eventually it got very upset with dlls etc apparently missing.
        The missing exporters seemed to be the extra ones ones you get with Pro i.e. Autcad etc.
        So for some reason it appears that when I download latest maintenance release back in Dec it looks like Pro it says its Pro but it is infact the free version. Maybe I had download the free version in haste 😳
        Anyway easy fix. I downloaded latest maintenance release again making sure its was for Pro(the second one down, I think I may have picked the one at the top of the list πŸ˜• ), and then just ran it, which just updated sketchup on my machine. That fixed my problem straight away.
        It don't know how this will affect your custom settings. My settings all stayed the same. ❓, but may be you have a different set up.
        Richcat
        • L
          lapx
          richcat thanks! That solved the problem.
