    SU-Artantis interiors
    26 Posts 7 Posters 3.7k Views 7 Watching
    • Y
      ypnos1
      Hello friends
      more of my recent work done with SU--Artlantis--photoshop
      Only sunlight and sky contribution used in artlantis
      no interior lights were turned on. each rendering took about 10-15 minutes at 2000x1600.
      Tight deadline -- fast renderings needed
      HOpe everybody likes
      Comments and crits are welcome
      Thanks for looking
      EDIT BY ADMIN: 2nd image too large. Removed from post.
      http://www.sketchucation.com/forums/scf/sas/Gallery/SketchUp_37_tagged_smallers.jpg
      http://www.sketchucation.com/forums/scf/sas/Gallery/SketchUp_37 copy_alternate-smalls.jpg
      • Y
        ypnos1
        sorry about the redundant views
        i hit submit instead of preview accidentally
        http://www.sketchucation.com/forums/scf/sas/Gallery/SketchUp_36 copy_smalls.jpg
        http://www.sketchucation.com/forums/scf/sas/Gallery/SketchUp_24 copy_pp-smalls.jpg
        • R
          robmoors
          Amazing renders, could do with a little less grain but two thumbs up here!
          Rob Moors
          Architecture Student
          • Y
            ypnos1
            Rob
            Actually the grain is something I added in Photoshop
            so i guess you don't like that part.
            Artlantis always renders grain free
            Thanks for you comments
            peace
            • S
              sepo
              I thought grain was added in PS. Also there is more postprocessing there, right.
              Could you post raw renders please.
              • Y
                ypnos1
                images straigt out of artlantis attached
                a bit flat
                that is why i post produce
                πŸ˜‰
                http://www.sketchucation.com/forums/scf/sas/Gallery/SketchUp_38s.jpg
                http://www.sketchucation.com/forums/scf/sas/Gallery/SketchUp_36s.jpg
                • R
                  robmoors
                  Good post processing work!, though I must ask why the grain?
                  Rob Moors
                  • J
                    jeff jacobs
                    Nice. The little bit of bloom and the grain really helps the Artlantis output which sometimes is a little "plastic-like".
                    • Y
                      ypnos1
                      Jeff
                      Hello old friend
                      Glad you took a look at my drawings.....you were the reason I bought Artlantis way back. I was really impressed with the work you did with it when you were still using it.
                      The grain and bloom effect is for the exact reason you specified. It helps to soften the image up even though it isn't exactly photo real. It's more of a mood thing. Still can't beat artlantis times with any other renderer. Perfection has a price - and with a single processor like mine the price is time.
                      So i'm still using ARtlantis for my interior and KT for exteriors.
                      Thanks for checking out my work
                      Glad to finally find this new forum. These are my first posting ins the forum.
                      • EdsonE
                        Edson
                        hi ypnos1,
                        I like your renders very much. I am very interested in your output as I am beginning to explore artlantis in conjunction with sketchup and vectorworks. I shall be keeping an eye on you, in case you don't mind it.
                        regards,
                        edson
                        http://www.mahfuz.arq.br
                        • Y
                          ypnos1
                          That's cool
                          I'll post more Sketchup - Artlantis images for you to check out....not in this thread necessarily but in others as well.
                          Glad you like my work
                          • Y
                            ypnos1
                            ok
                            here you go Edson
                            Some earlier design versions....the renderings are a bit different as well.
                            Comments and crits welcome
                            EDIT BY ADMIN: 1st image too large. Removed from post.
                            http://www.sketchucation.com/forums/scf/sas/Gallery/SketchUp_24-c-w neon glass 300 radiositys.jpg
                            • EdsonE
                              Edson
                              well, I like them very much and look forward to when I will be able to produce something like that. as for crits, I will leave that to others for the time being: my knowledge of rendering is not enough to venture into that.
                              a question. would you have any recommendations as to how to export the SU model into artlantis? 3DS has been working fine for me (that is, as far as exporting goes) but whenever I tried to export in artlantis format (ATL) my machine crashes.
                              regards.
                              edson
                              • Y
                                ypnos1
                                Try and reinstall the program if the .atl exporter crashes. This is my best recomendation.
                                I also read somewhere that Artlantis R 1.2.5 (i think) can import SU files directly.
                                Good luck with that
                                • EdsonE
                                  Edson
                                  Good luck with that
                                  I assume you are telling me to reinstall SU, right? alas, my copy of artlantis is the 1.2.2.
                                  thanks.
                                  edson
                                  • Y
                                    ypnos1
                                    first i would try and reinstall the exporter that can be downloaded from the artlantis website
                                    I'm not suggesting to reinstall SU because that could be a complicated task.
                                    Try opening up your SU file in ARtlantis directly ----- let me know if that works
                                    Ypnos
                                    • EdsonE
                                      Edson
                                      I have installed artlantis 1.2.5 but it does not offer SU as a valid format for import. I'll try to reinstall the plugin.
                                      edson
                                      • Y
                                        ypnos1
                                        I think you can literally open an SU file in ARtlantis not import it.
                                        Try that
                                        • EdsonE
                                          Edson
                                          Try that
                                          there is no import option in ARtlantis (at least i could not find it). when I tried to open an SU file all of them appeared grayed out in the dialogue box. only files with the extensions atl and 3ds could be opened among the ones in my HD.
                                          • Y
                                            ypnos1
                                            ok
                                            i must be mistaken...post your problem on the abvent site...or at least search for it there. Surely others have encoutered the same problem.
                                            Sorry for not being able to help.
                                            • 1 / 2
