    SU-Artantis interiors
    26 Posts 7 Posters 4.1k Views 7 Watching
      robmoors
      Good post processing work!, though I must ask why the grain?
      Rob Moors
      Architecture Student
        jeff jacobs
        Nice. The little bit of bloom and the grain really helps the Artlantis output which sometimes is a little "plastic-like".
        • Y
          ypnos1
          Jeff
          Hello old friend
          Glad you took a look at my drawings.....you were the reason I bought Artlantis way back. I was really impressed with the work you did with it when you were still using it.
          The grain and bloom effect is for the exact reason you specified. It helps to soften the image up even though it isn't exactly photo real. It's more of a mood thing. Still can't beat artlantis times with any other renderer. Perfection has a price - and with a single processor like mine the price is time.
          So i'm still using ARtlantis for my interior and KT for exteriors.
          Thanks for checking out my work
          Glad to finally find this new forum. These are my first posting ins the forum.
          • EdsonE
            Edson
            hi ypnos1,
            I like your renders very much. I am very interested in your output as I am beginning to explore artlantis in conjunction with sketchup and vectorworks. I shall be keeping an eye on you, in case you don't mind it.
            regards,
            edson
            http://www.mahfuz.arq.br
            • Y
              ypnos1
              That's cool
              I'll post more Sketchup - Artlantis images for you to check out....not in this thread necessarily but in others as well.
              Glad you like my work
              • Y
                ypnos1
                ok
                here you go Edson
                Some earlier design versions....the renderings are a bit different as well.
                Comments and crits welcome
                EDIT BY ADMIN: 1st image too large. Removed from post.
                http://www.sketchucation.com/forums/scf/sas/Gallery/SketchUp_24-c-w neon glass 300 radiositys.jpg
                • EdsonE
                  Edson
                  well, I like them very much and look forward to when I will be able to produce something like that. as for crits, I will leave that to others for the time being: my knowledge of rendering is not enough to venture into that.
                  a question. would you have any recommendations as to how to export the SU model into artlantis? 3DS has been working fine for me (that is, as far as exporting goes) but whenever I tried to export in artlantis format (ATL) my machine crashes.
                  regards.
                  edson
                  • Y
                    ypnos1
                    Try and reinstall the program if the .atl exporter crashes. This is my best recomendation.
                    I also read somewhere that Artlantis R 1.2.5 (i think) can import SU files directly.
                    Good luck with that
                    • EdsonE
                      Edson
                      Good luck with that
                      I assume you are telling me to reinstall SU, right? alas, my copy of artlantis is the 1.2.2.
                      thanks.
                      edson
                      • Y
                        ypnos1
                        first i would try and reinstall the exporter that can be downloaded from the artlantis website
                        I'm not suggesting to reinstall SU because that could be a complicated task.
                        Try opening up your SU file in ARtlantis directly ----- let me know if that works
                        Ypnos
                        • EdsonE
                          Edson
                          I have installed artlantis 1.2.5 but it does not offer SU as a valid format for import. I'll try to reinstall the plugin.
                          edson
                          • Y
                            ypnos1
                            I think you can literally open an SU file in ARtlantis not import it.
                            Try that
                            • EdsonE
                              Edson
                              Try that
                              there is no import option in ARtlantis (at least i could not find it). when I tried to open an SU file all of them appeared grayed out in the dialogue box. only files with the extensions atl and 3ds could be opened among the ones in my HD.
                              • Y
                                ypnos1
                                ok
                                i must be mistaken...post your problem on the abvent site...or at least search for it there. Surely others have encoutered the same problem.
                                Sorry for not being able to help.
                                • W
                                  Will03
                                  I'd like to know the proccess that you've used to soften those images! I love that effect, it adds sooo much more depth to your image! great work!
                                  • Y
                                    ypnos1
                                    ok ok
                                    here is the secret.....download this photoshop plug-in. http://www.optikvervelabs.com/ It works really well and give lots of presets to play with. In fact is is great for images straight out of sketchup. I'll create a few examples later and post them for everybody to see.
                                    Best of all its free! God bless'm!
                                    I'll show you guys how to create areas of light/atmosphere in photoshop at another time. I'm at work now and have to go. Glad you guys like my work.
                                    Best of all all of these tricks happen very quickly once you get the hang of them.
                                    Ypnos
                                      richcat
                                      Thanks Ypnos.
                                      I just download and tried it on some my renders and its worked wonders.... and its free!
                                      Thanks again.
                                      Richcat
                                      • EdsonE
                                        Edson
                                        @ypnos1 said:
                                        ok ok
                                        Ypnos
                                        it is only for PC! 8O
                                        edson
                                        • Y
                                          ypnos1
                                          That sucks!
                                          since i'm not a mac user i never think to check these things.....however if you buy mac parrales with a pc version of Photoshop you should be able to run it πŸ˜• πŸ˜’
                                          I'm going on vacation and will be drowning in work until i leave. I'll do my best to create the tutorial i promised but i won't promise. I'll post it under the rendering section of this website.
                                          Ypnos
                                          • W
                                            Will03
                                            beautiful plugin! thanks for the link! please feel free more than welcome to make some tutorials for us lesser photoshop users!
                                            Thanks again!
