    Quarter Sawn Oak texture
    31 Posts 11 Posters 9.7k Views 11 Watching
    • O Offline
      oldworld124
      Hello Gaieus,
      Thanks for the reply. However, I tried saving massmaterialimporter.rb into the Plugins section of Google SK7 and it does not show up. I must be doing something wrong. I copied and pasted in Notepad as you explained and named everything correctly and saved it in Plugins. The Folder does not show up at all. I then saved it in My Documents to see if it would show up. It does but only opens in Excel. The script is the same as is on the site. Your help and any from others is much appreciated.
      Thanks, John
        It mightnot show up in the Plugins menu but somewhere else (I don't have it so don't know).
        It's interesting though that it opens in Excel. Can you open it in Notepad? Do you see any strange in the text if you open it?
        • O Offline
          oldworld124
          I have been able to copy and save it to Notepad and reconfigured it to open in Notepad
          instead of Excel. The problem is that I cannot get it to go to SKP7
          Plugins. It only opens in Notepad and is in it's proper script as is shown on the Ruby Library. It will not go into Plugins on SK7. Am I copying too much? Could someone please give me some pointers as to how to get this to run? It seems like a very useful Plugin. I am a quick learner. I just needs some pointers.
          Thanks, John
            @oldworld124 said:
            ...The problem is that I cannot get it to go to SKP7 Plugins. It only opens in Notepad...
            Well, then in Notepad, save the file as is - into the SU 7 Plugins folder. Are you saying you cannot svae there?
              John,
              You say it won't go into Plugins. Do you mean you aren't seeing "Import Materials" in the Plugins menu in SketchUp? Or you can't save it as an rb file in the Plugins folder?
                mirjman
                click on the arrow in the top right and us "save collection as" to quickly save all the imported materials
                • O Offline
                  oldworld124
                  When I save it into SKP 7 Plugins it only saves it as a .txt file. Isn't it supposed to be an .rb file? It will not show up in the Plugins window if it is a .txt file. I can find it if I do a file search for it. If it is to be an .rb file or other file name, can someone show me how to do this. I have downloaded a few plugins and have this same problem. It is only with the plugins that need to be copied and saved of the text type. There are some plugins I have found that are already set up to save as an .rb file that have loaded correctly into tool, plugins, etc.
                  Thanks, John
                    Have you tried renaming the TXT file in the Plugins folder with the file extension RB?
                    • O Offline
                      oldworld124
                      The problem is that it can only be saved as .txt file. I have tried and cannot change it to an .rb file. I copied this from the Ruby Library as instructed and pasted it in notepad. Then I clicked on file save as and saved to SKP 7 plugins. It is a text only file. It will only open in notepad as normal text the same way I originally pasted it. I know there is a way to make these plugins work. I just need the knowledge. Others don't seem to have any problem at all. I have a few others that are the same way. They show as text files. The only ones I have been able to activate are the ones I downloaded as .zip files. The person who put them on the Ruby Library already had them configured to be able to send to the tools or plugins area in SKP.
                      Thanks, John
                        What happens if go to the Plugins folder via Windows Explorer, right click on the name and choose Rename? Can you then change the extension from txt to rb?
                        Forget about opening it in NotePad or anything else for the moment.
                        • O Offline
                          oldworld124
                          Just wanted to say thank you to all who helped me on this one. I finally got it figured out. Notepad was not working properly. I downloaded notepad++ and now have full control over file naming.
                          Thanks Again, John
                          • 2 / 2
