    Quarter Sawn Oak texture
    31 Posts 11 Posters 10.3k Views 11 Watching
    • I
      itisonlyi
      I got this excellent advice in the Google Group Sketchup forum
      http://groups.google.com/group/sketchup/
      ...there's a dropdown menu pick called Save Library As...
      That will save your entire In-Model Material Library as a named
      library, like Wood or Carpet and Textiles. The new library will
      correspond to a like-named folder under C:\Program Files\Google\Google
      SketchUp 6\Materials, and the folder will contain one .skm file for
      each texture.
      Hope others find it useful
      And thank you again for your help
      Steve
        remus
        cheers, thats very useful, i was just going to do it by dragign all the materials into their respective folders πŸ˜›
        • O
          oldworld124
          I'm a Newbie here on Sketchup and Ruby Plugins.
          Could someone explain to me how to download this massmaterialimporter.rb Plugin? When I go into the Plugins library and click on this Plugin it comes up with script. Is there a way to download it normally or do I need to do it some other way. I would like to set up a materials library and do not know how.
          Thanks, John
            Aidus
            Wow! Amazing textures! Thanks!
            CPU: Intel Core i7 Extreme Edition 965
            RAM: OCZ Gold DDR3 1600MHz 12Gb
            Video: Asus Radeon HD4870 X2 2Gb
            Mobo: Asus P6T Deluxe 1366 Intel X58
            • GaieusG
              @oldworld124 said:
              ...Could someone explain to me how to download this massmaterialimporter.rb Plugin...?
              Hi John,
              Yes, ruby files are simple text files (only difference is the *.rb extension vs. the *.txt extension). Web browsers and text editors therefore handle both the same way. Anyway, there are two easy ways to save them:
              1. Right click on the file and "Save as..." (or something like that in different browsers) into the Plugins folder. Make sure to give it the same name as it is written on the download page and add the .rb extension (in case it is not added automatically).
                NEVERgo to File > save page as... in your browser because it will add a whole bunch of html codes to the text file and it will get corrupted.
              2. When you have already clicked on it and the text is opened in your browser, select all (Ctrl A) > Copy (Ctrl C) and paste it (Ctrl V) into a plain text editor (like Notepad - NEVER a Word processor like MS Word or such!!!).
                Now save it (with the same naming rules as above) into your Plugins folder.
              • O
                oldworld124
                Hello Gaieus,
                Thanks for the reply. However, I tried saving massmaterialimporter.rb into the Plugins section of Google SK7 and it does not show up. I must be doing something wrong. I copied and pasted in Notepad as you explained and named everything correctly and saved it in Plugins. The Folder does not show up at all. I then saved it in My Documents to see if it would show up. It does but only opens in Excel. The script is the same as is on the site. Your help and any from others is much appreciated.
                Thanks, John
                • GaieusG
                  It mightnot show up in the Plugins menu but somewhere else (I don't have it so don't know).
                  It's interesting though that it opens in Excel. Can you open it in Notepad? Do you see any strange in the text if you open it?
                  • O
                    oldworld124
                    I have been able to copy and save it to Notepad and reconfigured it to open in Notepad
                    instead of Excel. The problem is that I cannot get it to go to SKP7
                    Plugins. It only opens in Notepad and is in it's proper script as is shown on the Ruby Library. It will not go into Plugins on SK7. Am I copying too much? Could someone please give me some pointers as to how to get this to run? It seems like a very useful Plugin. I am a quick learner. I just needs some pointers.
                    Thanks, John
                    • GaieusG
                      @oldworld124 said:
                      ...The problem is that I cannot get it to go to SKP7 Plugins. It only opens in Notepad...
                      Well, then in Notepad, save the file as is - into the SU 7 Plugins folder. Are you saying you cannot svae there?
                        John,
                        You say it won't go into Plugins. Do you mean you aren't seeing "Import Materials" in the Plugins menu in SketchUp? Or you can't save it as an rb file in the Plugins folder?
                          mirjman
                          click on the arrow in the top right and us "save collection as" to quickly save all the imported materials
                          • O
                            oldworld124
                            When I save it into SKP 7 Plugins it only saves it as a .txt file. Isn't it supposed to be an .rb file? It will not show up in the Plugins window if it is a .txt file. I can find it if I do a file search for it. If it is to be an .rb file or other file name, can someone show me how to do this. I have downloaded a few plugins and have this same problem. It is only with the plugins that need to be copied and saved of the text type. There are some plugins I have found that are already set up to save as an .rb file that have loaded correctly into tool, plugins, etc.
                            Thanks, John
                              Have you tried renaming the TXT file in the Plugins folder with the file extension RB?
                              • O
                                oldworld124
                                The problem is that it can only be saved as .txt file. I have tried and cannot change it to an .rb file. I copied this from the Ruby Library as instructed and pasted it in notepad. Then I clicked on file save as and saved to SKP 7 plugins. It is a text only file. It will only open in notepad as normal text the same way I originally pasted it. I know there is a way to make these plugins work. I just need the knowledge. Others don't seem to have any problem at all. I have a few others that are the same way. They show as text files. The only ones I have been able to activate are the ones I downloaded as .zip files. The person who put them on the Ruby Library already had them configured to be able to send to the tools or plugins area in SKP.
                                Thanks, John
                                  What happens if go to the Plugins folder via Windows Explorer, right click on the name and choose Rename? Can you then change the extension from txt to rb?
                                  Forget about opening it in NotePad or anything else for the moment.
                                  • O
                                    oldworld124
                                    Just wanted to say thank you to all who helped me on this one. I finally got it figured out. Notepad was not working properly. I downloaded notepad++ and now have full control over file naming.
                                    Thanks Again, John
                                    • 2 / 2
