    Recent Project
    10 Posts 6 Posters 2.0k Views 6 Watching
    • P
      Phil Rader AIA
      Here is a link to a recent project of mine. A complete remodel and addition to a single family home.
      http://www.philrader.com/projects/parkway/index.html
      Any thoughts about the project and Sketchup illustrations would be appreciated.
      Thanks.
      Phil Rader, AIA
      • T
        tomsdesk
        Phil...really nice design and looks to be a sweet model too!
        The image compositions work quite well for me, but IMHO (since you asked :`) the straight SU output always has a hazy quality. I fussed with the first image a bit: first softened the whole thing to take down the textures a bit; punched up the color intensity across the image a bit by adding a couple of side-merged overlay layers (stronger colors fading to no change across the image corner to corner); then burned in a slight dot pattern texture overall to punch up the areas of flat color. If I had had your edges layer, I would have burned or multiplied that over the top to bring back some of the hard edges. Whadaya think?
        2.5D Trees & Shrubs!
        • P
          Phil Rader AIA
          Yes that pops better. I am just such a lazy old fart I just hit export>>jpg from SU and that's it. I suppose I could create Photoshop actions and batch process a bunch of images but to individually open and alter each exported image would be too much time.
          I do agree that the punched up contrast and saturated colors are jazzier.
          Hey I wonder if this is possible with Ruby?
          well anyway thanks for the comments. Your opinion is quite valuable.
            Phil, I have also found that the straight output from SU seems a bit flat. Since I'm also a lazy old fart, I run the output through Picasa. All I do is open the image there and hit Auto Contrast. that seems to do the trick most of the time. Ctrl+S saves the correction and I'm finished.
            I like this house. Is it going to be built locally? If so, what does it take to deal with snow loads? I ask because my S-I-L is looking to replace her house which overlooks Medicine Lake and I've been trying to convince her that she needs to do something along the lines of what you've drawn.
            • marked001M
              marked001
              very cool design, phil... i like.
              http://www.revision21vis.com
              instagram: revi21on
              • D
                dylan
                It is a nice looking house and the sort of thing I really like.
                One thing concerning the image. The barrel to the right, is it the correct scale? It seems quite large to me.
                http://dmdarchitecture.co.uk/
                • P
                  Phil Rader AIA
                  Dylan that was taking a smaller barrel component either from Form Fonts or 3dwarehouse and scaling it up. I agree it looks too large but when your are modeling at 90 miles per hour sometimes you miss things.
                  I gather I could do some research on rain water cisterns and find something appropiate, but alas I'm to lazy.
                  • D
                    Dave M
                    That's a beautiful house, and I particularly like the way the elevations turned out. One question: where does the overflow for the rain barrel go? Or is that a "for later" detail, once you're past the conceptual phase?
                    • P
                      Phil Rader AIA
                      I guess it will have an overflow drain at the top.
                      I have not fully developed the concept since it's most likely a project that will not be built as conceived.
                      http://www.rain-barrel.net/rain-catcher-water-barrels.html
                      That's what I had in mind but I guess I could think bigger and design an underground cisstern
                      • D
                        dylan
                        I used the same component for the exact same thing recently on a job πŸ˜„
