    International characters
    4 Posts 2 Posters 816 Views 2 Watching
    • Al HartA Offline
      Al Hart
      I am trying to work out how to support Extended Ansi characters in ruby.
      I can execute these two statements from the ruby console:
      satt1 = "Grösse"
      satt2 = "Größe"
      (The first word doens't exist but it highlights that the umlauted-o works, but not the double-SS character)
      But when I include them in ruby source, the second will not load into Ruby.
      	def test_att1
      		satt1 = "Grösse"
      		printf("SATT1; %s\n",satt1)
      	end#def
      	def test_att2
      		satt2 = "Größe"
      		printf("SATT2; %s\n",satt2)
      	end#def
      The word Größe is stored in the source file as extended Ascii: (hex) 47 72 94 E1 65
      Is there a way to convert extended Ascii to multi-byte characters and/or can I switch to using Unicode?
      I am using MSVC for my ruby editor - is there a way to enter accented characters better in MSVC?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • fredo6F Offline
        fredo6
        This happens with French accents as well (I am using Notepad++ as my Ruby editor).
        The method is to prefix the special character with a backslash within the string.
        For instance "Gr\ö\βe"
        • Al HartA Offline
          Al Hart
          Thanks.
          That worked and also create a multi-byte string, rather than an extended ansi string.
          Al Hart
          • fredo6F Offline
            fredo6
            This is normal. For German characters, you do not need Unicode. So you should swith it off.
            For MSVC, I don't know if there is an efficient way to enter the extra characters. I am personally using Notepad++.
