    Multi-layers wall tool is back !
    17 Posts 5 Posters 4.7k Views 5 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      I've completely re-coded an old script (2004) that lets you draw walls made of up to 4 different layers/Materials.
      Script options and commands:
      • list, create, delete save, load, wall styles, wether within the SKP or in external files for later use,
      • draw a wall segment,
      • draw walls from connected lines/curves/arcs,
      • draw a wall from a face with/without openings,
      • create openings in walls.
      It's here:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=3550
      DB
      • jujuJ Offline
        juju
        thx for the continued effort Didier!
          seasdes
          Thanks for the update Didier. However, the wall heights worked for a few times and now they all have zero height. What might I be doing wrong. Where are the wall types kept (maybe I need to delete preferences???).
          Walter
          Using Sketchup Pro 2019
            bellwells
            Didier, Your tireless efforts are very much appreciated. Thank you. And thanks for enlarging the "date" column on your web site.
            Ron
            • JClementsJ Offline
              JClements
              Didier,
              You should be commended for not only a well thought out script, but EXCELLENT instructions in your PDFs.
              I wish this was done more for other scripts.
              Thanks for your attention to detail.
              John
                JClements
                See attachment please.
                No matter what wall justification I use, resulting wall seems to be offset from line when using "Lines to wall".Example using a simple, 2-Layer wall (one 12" and the other 1" thick)
                  Didier Bur
                  Hi John,
                  amazing... 😲 😳
                  I used your style in your file and... it didn't work as expected (because of the materials that have different names in french).
                  Is the error reproductible ? Is this happening in every model ?
                  Hi seasdes,
                  Wall style are kept within the SKP file as model attributes (so you cannot "see" them anywhere)
                  Walls heights: Is the error reproductible ? Is this happening in every model ?
                  DB
                    JClements
                    Didier, did you try creating a new style using the English Version using your material names, then doing the "Line to wall" routine. Perhaps there's difference between the French and English scripts?
                    I get same offset result in all models.
                      seasdes
                      @didier bur said:
                      Hi John,
                      amazing... 😲 😳
                      Hi seasdes,
                      Hi Didier
                      It is reproducable in all files and new ones and after rebboting the PC. Maybe there is a clash with another Plugin. I also use your plugin 'Justified Wall Segment Group'(JWSG) and find it extremely useful for every project. I have tried removing JWSG plugin but there is no change in behaviour
                      Walter
                        seasdes
                        Hi Didier
                        I deleted all of the plugins except the Multi-Layers Wall Tool. My problem still exists.
                        Walter
                          Didier Bur
                          Hi all,
                          Wall justification bug fixed (same link to download new release).
                          2PI/3 was muddled up with 3PI/4 😳
                          Sorry for the inconvenience.
                          DB
                            JClements
                            Didier, is the updated version (2) the one currently on the server?
                            Here is my latest result after re-downloading. Looks like it still has problems.
                            MultiWall V2.skp
                              Didier Bur
                              Ok Ok, sorry again, it has been fixed (same link at the depository).
                              Pfff... πŸ˜’
                              DB
                                Didier Bur
                                I wisk I knew why when testing before releasing, it works, and when someone else uses it it doesn't... πŸ‘Ώ πŸ‘Ώ πŸ‘Ώ
                                DB
                                  Didier Bur
                                  Just to put this thread on top of stack eh eh...
                                  Patch posted here:
                                  DB
                                    JClements
                                    Didier, its your pest again πŸ˜•
                                    I downloaded the latest version and I don't think right-alignment works.
                                    MultiWall Right Alignment may have a bug.skp
                                      JClements
                                      Didier,
                                      Thanks. It seems to work as you described. Appreciated the PDF instructions as well.
                                      John
