Multi-layers wall tool is back !
Hi all,
I've completely re-coded an old script (2004) that lets you draw walls made of up to 4 different layers/Materials.
Script options and commands:- list, create, delete save, load, wall styles, wether within the SKP or in external files for later use,
- draw a wall segment,
- draw walls from connected lines/curves/arcs,
- draw a wall from a face with/without openings,
- create openings in walls.
It's here:
http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=3550 -
thx for the continued effort Didier!
Thanks for the update Didier. However, the wall heights worked for a few times and now they all have zero height. What might I be doing wrong. Where are the wall types kept (maybe I need to delete preferences???).
Walter -
Didier, Your tireless efforts are very much appreciated. Thank you. And thanks for enlarging the "date" column on your web site.
Didier,
You should be commended for not only a well thought out script, but EXCELLENT instructions in your PDFs.
I wish this was done more for other scripts.
Thanks for your attention to detail.
John
See attachment please.
No matter what wall justification I use, resulting wall seems to be offset from line when using "Lines to wall".Example using a simple, 2-Layer wall (one 12" and the other 1" thick)
Hi John,
amazing...
I used your style in your file and... it didn't work as expected (because of the materials that have different names in french).
Is the error reproductible ? Is this happening in every model ?Hi seasdes,
Wall style are kept within the SKP file as model attributes (so you cannot "see" them anywhere)
Walls heights: Is the error reproductible ? Is this happening in every model ? -
Didier, did you try creating a new style using the English Version using your material names, then doing the "Line to wall" routine. Perhaps there's difference between the French and English scripts?
I get same offset result in all models.
@didier bur said:
Hi John,
amazing...
Walls heights: Is the error reproductible ? Is this happening in every model ?Hi Didier
It is reproducable in all files and new ones and after rebboting the PC. Maybe there is a clash with another Plugin. I also use your plugin 'Justified Wall Segment Group'(JWSG) and find it extremely useful for every project. I have tried removing JWSG plugin but there is no change in behaviourWalter
Hi Didier
I deleted all of the plugins except the Multi-Layers Wall Tool. My problem still exists.Walter
Hi all,
Wall justification bug fixed (same link to download new release).
2PI/3 was muddled up with 3PI/4
Sorry for the inconvenience. -
Didier, is the updated version (2) the one currently on the server?
Here is my latest result after re-downloading. Looks like it still has problems.
Ok Ok, sorry again, it has been fixed (same link at the depository).
Pfff...
I wisk I knew why when testing before releasing, it works, and when someone else uses it it doesn't...
Just to put this thread on top of stack eh eh...
Patch posted here:
Didier, its your pest again
I downloaded the latest version and I don't think right-alignment works.
Didier,
Thanks. It seems to work as you described. Appreciated the PDF instructions as well.
John
