    No API help for importer class?
    3 Posts 2 Posters 826 Views 2 Watching
      toxicvoxel
      Why is there no help topic for this class?
      http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/ruby-importer.html#load_file
      Does anybody have any info relating to methods for this class?
        import
        The import method is used to load a file by recognizing the file extension and calling appropriate importer.
        Syntax
        status = model.import "path+filename", show_summary
        Arguments
        “path+filename” – the path and name of the file to import. [It works out the importation type from the file's suffix of .dwg/.dxf/.skp/ etc]
        show_summary - true if you want to show a summary window, false if you do not want to show a summary window.
        Return Value
        status – true if successful, false if unsuccessful
        so I'd expect that:
        Sketchup.active_model.import("C;\\...FULL_PATH_TO...\\my.dwg",false)
        should work [it does].
        Incidentally the equivalent model.export(filepath,false) method also works...
          toxicvoxel
          Thanks mate. Thats very helpful.
