    Changing default values?
    3 Posts 2 Posters 864 Views 2 Watching
    • PixeroP
      Pixero
      Is there a way to have one parameter changing the default values in other parameters?
      Let's say I have a dropdown menu with two options and if I choose the first option the default values of some input field would be 1 and if I choose the second it would be 2.
      It's probably trivial but my brain is slow today.... 😳
      • TIGT
        With web based dialogs it's probably 'yes': BUT the basic SUp-ruby dialog has its values fixed as it opens: only the user input changes input-fields/drop-down selections: you need to OK/Cancel to get it to change values - at that point it could change them and reopen itself with the new values displayed ?
        Can you give a more concrete example ?
        • PixeroP
          Pixero
          Okay, thanks for your reply.
          I was actually thinking of writing a web dialog for this script at a later stage.
          Just thought I'd test some functionality first without it.
          I guess I'll have to dive into the sea of web dialogs then... πŸ˜•
