    Save skp file errors
    4 Posts 4 Posters 1.1k Views 4 Watching
    • N Offline
      not registered yet
      I wanted to cycle through my library skp files and make sure the view of the geometry was centred.
      I am having some problem with Sketchup.active_model.save which is not working how I expect (see below). Any thoughts anybody?
      Bill Wood
      PS I figured out about find_support_files as per my earlier question
      paths = Sketchup.find_support_files ("skp","Components/Architecture/")
      puts paths[0].class # type String
      Sketchup.open_file paths[0] # true file opened
      Sketchup.send_action "viewZoomExtents:"
      Sketchup.active_model.active_view.invalidate
      curpath = Sketchup.active_model.path
      returns C:\Program Files\Google\Google SketchUp 6\Components\Architecture\Door-SglExtHeaderWLite 3'-0x6'-8.skp
      puts curpath.class # type String
      Sketchup.active_model.save curpath
      gives Error:
      #<Exception: (eval):32:in `save': Invalid filename>
      fname = File::basename(curpath)
      puts fname.class # type String
      Sketchup.active_model.save fname # returns true but does not save actual file
      curpath = "C:/Program Files/Google/Google SketchUp 6/Components/Architecture/Door-SglExtHeaderWLite 3'-0x6'-8.skp"
      if I change \ to / for curpath returns true but does not save actual file
      [BillW]
        azuby
        Have you also tried to use filenames without inverted comma / apostrophe?
        azuby
          todd burch
          FYI. The default path for model.save is not where you would expect, nor, the current working directory. Save a unique name and search for it. It's probably going to C:\Documents and Settings\Default User\Local Settings blah, blah or some such location. I've put in an enhancement request to make it more obvious/intuitive/documented.
          Todd
          • Al HartA Offline
            Al Hart
            Bill,
            Were you ever able to save the .SKP where you wanted them?
            I tried saving it with the base name (xxx.skp) and no path. I don't think it resaved it, althoug it returned true.
            sname = File.basename(sfile)
            model.save(sname)
            I then saved it with new names using:
            component_name = File.basename(sfile,".*")
            sname = component_name + "_new.skp"
            model.save(sname)
            This seems to have worked (saving a new SKP in the original folder)
            Al Hart
            IRender nXt from Render Plus
