    SU6 SKM processing
    3 Posts 2 Posters 895 Views 2 Watching
    • tbdT Offline
      tbd
      does anyone knows how to get the texture file from a material ?
      sketchup.com is down and I dont have a mirror of SU6 Ruby help and in SU6 textures are stored inside .skm (which are renamed .zip files) versus SU5 where all textures were stored normally in Materials subdir.
      one way is to TextureWrite it but I dont like to clutter the HDD for that πŸ˜„
      SketchUp Ruby Consultant | Podium 1.x developer
      http://plugins.ro
        I wrote this script a while ago. It was meant for getting 'color-by-layer' colors , but with the right settings it also exports the colors' textures; if you have it pre-set appropriately...
        There might be something in there you can use ? It's a hack but it works...
        If you see my post earlier of today about 'layer colors' you can seen in the associated script how you might use this method to get the model's materials...
        OBJlayercols.txt
        • tbdT Offline
          tbd
          that means that the user must export as OBJ first - not acceptable πŸ˜„
          so I think I will use TextureWriter as there is no Ruby method that points to the .skm file to do a .zip parsing of .xml files. urgh πŸ˜„
          thanks anyway
          http://plugins.ro
