    What is wrong with this script?
    9 Posts 3 Posters 1.8k Views 3 Watching
    • PixeroP Offline
      Pixero
      I got inspired by a thread here about shadow threshold and thought I'd try it, but I get an error: #<ArgumentError: comparison of Float with Array failed>
      What am I doing wrong? πŸ˜•
      #  Name ; JS Shadow Threshold
      #  Description ; Sets cast shadow with a threshold
      #  Author ; Jan Sandstrom (http://www.pixero.com)
      #  Date ; 12 Aug 2007
      require 'sketchup.rb'
      def jsShadowThreshold
        model = Sketchup.active_model
        entities = model.active_entities
        ss = model.selection
        if ss.empty?
          UI.messagebox("Nothing selected!")
          return nil
        # Dialog
      	@thresh = 0.7 if not @thresh
      	prompts = ["Shadow threshold; "]
      	values = [@thresh]
      	results = inputbox(prompts, values, "Shadow threshold")
      	thresh = results
      	@thresh = thresh
      	ss.each {|e|
      		next if not (e.is_a? Sketchup;;Face)   #Ignore items in the selection that are not faces.
      		alpha = e.material.alpha
      		if (alpha < thresh) #Error; #<ArgumentError; comparison of Float with Array failed>
      			e.cast_shadows= false
      		else
      			e.cast_shadows= true
      		end #if
      	} #end of ss.each
      end #jsShadowThreshold
      if( not file_loaded?("jsShadowThreshold.rb") )
          UI.menu("Plugins").add_separator
          UI.menu("Plugins").add_item("JS Shadow Threshold") { jsShadowThreshold  }
      file_loaded("jsShadowThreshold.rb")
        todd burch
        results, as returned from inputbox, is an array.
        Todd
          thresh=results[0]
          will work...
          • PixeroP Offline
            Pixero
            Thanks, but now another error has occured. πŸ˜•
            For the following line:
            alpha = e.material.alpha   #Error; #<NoMethodError; undefined method `alpha' for nil;NilClass>
            Sorry if it's elementary but I can't seem to get it right.
            Thanks in advance.
            /Jan
              todd burch
              e is most likely valid. When e does not have a material assigned, the .material method returns nil.
              Todd
              • PixeroP Offline
                Pixero
                Ok, progressing veeery slowly.... 😳
                When I assign a material to the faces I now get this:
                e.cast_shadows= false   #Error; #<NoMethodError; undefined method `cast_shadows=' for #<Sketchup;;Face;0x7532bb0>>
                If I remove the e in front of cast_shadows I don't get the error but nothing happens.
                Sigh... 😒
                  todd burch
                  The doc is bad. Use .casts_shadows=.
                  To see the methods a entities allows, in the Ruby Console, enter (for example, with a face)
                  (face.methods - Object.methods).sort.join("\n")
                  Todd
                  • PixeroP Offline
                    Pixero
                    Thanks that did it!
                    Now if only I can get it to work with grouped objects...
                    • PixeroP Offline
                      Pixero
                      Got it working! Thanks for the help. Read more here:
                      http://www.sketchucation.com/scf/viewtopic.php?f=9&t=1986
