    Display Settings Dialog box
    3 Posts 2 Posters 782 Views 2 Watching
      dammerel
      Hi all
      Im using SU pro and i cant find the display setting dialog box, i believe it should be in windows|display settings
      Thanks Andrew
        Andrew,
        "Display settings" is now (with SU6) called "Styles". You can firnn it right there: in the Window menu.
        Since SU5 (when it was called "Display settings") this menu/function has changed the most this is probably why they renamed it.
        Yet true: the SU Guide or the tutorials need some update...
        πŸ˜„
          dammerel
          Thanks..
