    Drawing irregular floor pattern problem
    3 Posts 2 Posters 1.1k Views 2 Watching
    • syburnS
      syburn
      sigh.......its me again.
      If i am using line tool to trace out a curved irregular floor pattern (so that i can add a material to it), how to constrain all these lines to a base axis so that it will make a face. Using shift does not work as it only lets me draw squared shapes at red gree axis.
      P: syburn
      • GaieusG
        If you go "Top view" (Standard views), SU will tend to draw on the red/green (horizontal) plane.
        However you can also draw a huge rectangle before starting and use that as a "drawing board" - SU will tend to draw "on face".
        • syburnS
          syburn
          much appreciated!!!
          P: syburn
