    Wierd Material problem
    extensions
    3 Posts 2 Posters 1.3k Views 2 Watching
    • P Offline
      perk
      Ok I have this tree branch etching on some glass to the left. In SU it is vertical but when I bring it into KT it rotates 90 degrees. Anyone know why this is.
      It's a little hard to see in this view but if you look close you can see it
      • jenujacobJ Offline
        jenujacob
        hi perk... which version of su2kt plugin are u using??
        i've heard that the older ver. had this rotating texture problem... the newer version (3.0) has fixed this...
        regards,
        jj
        • P Offline
          perk
          I am using the older version. I had trouble yesterday downloading the new version and getting it to work so I went back to the old. I will try the new again. Thanks.
