    A road design
    2 Posts 3 Posters 1.3k Views 3 Watching
    • D
      dammerel
      Hi guys
      have a look at the attached file, how can I "paint" the road with a material?
      because it is not co-planar? Andrew
      test road.skp
      • R
        Rodentpete
        Ok, explode the terrain group and intersect with the hidden 'road' block to get the intersection lines actually on the terrain, then select the eraser and Ctrl click on the lines you want to soften. You'll be left with the road as one surface to texture.
