πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Component insertion point
5 Posts 2 Posters 3.6k Views
  • G Offline
    Glenn at home
    Is there a way to set a component's insertion point? This is pretty easy to do in AutoCAD but I just can't seem to find a way to do this in SU. Does anyone know of a way to set these? TIA πŸ˜„
    Glenn
    SketchUp Pro 2024/2025 Dell XPS 8950 i9-12900K 64GB Ram RTX 3080
      Daniel
      Load your component into your model, right click and select "change axis". After changing the axis, if you look under the "in model" tab in the component browser, you will see your component with the revised insertion point - it will have the same name as the original component followed by #1 (#2, #3 and so on). You can then right click on it in the browser and select "save as" and save it to your component library.
      My avatar is an anachronism.
      • G Offline
        Glenn at home
        Thanks Daniel. I must have missed the "change axis". I right clicked on the component and didn't see this. It was late and I am not surprised that I didn't see it πŸ˜‰
        Thanks again
          Daniel
          Your welcome. Glad I could b helpful. Maybe that should be a request for the next version - a "change insertion point" option.
          • G Offline
            Glenn at home
            I think so. As you way be can tell I have an extensive Acad background and I think that having the ability to set the insertion point at time of block/component creation would be a great asset. Thanks again for the assistance πŸ˜„
