    Astral Bench
    4 Posts 3 Posters 1.0k Views 3 Watching
    • arqpadaoA Offline
      arqpadao
      Hi all
      Astral Bench
      Designer: Per Borre.
      The unique Astral bench was designed in 1979 and has won a host of awards for its sculptural shape and innovative construction. It comprises only two repeat elements that go together to create the back and seat. The construction forms a semi-circle whereby the bench bears its own weight and creates a unique seated sculpture. The bench is made from lacquered maple or ash. It is also available oiled teak for outdoor use. Astral is also made as a straight bench.
      Regards
      Bench_astral.skp
      fernando padão
      arquiteto
      porto alegre - brasil
      http://arqpadao.blogspot.com
        mateo soletic
        Fernando,
        thanks for sharing, its a great model.
        Concept Illustrations
          SchreiberBike
          Very nice model and especially nice design. What holds it together? From pictures I saw on-line, there is some kind of connection at the extremes and the center, but I couldn't tell if it was a cable with a spacer, or bolts, or what.
          • arqpadaoA Offline
            arqpadao
            Good Morning, Mateo and SchreiberBike.
            thanks.
            SchreiberBike, Do not I know for certain, but I believe that are put spacer between the pieces and intended with an cable.
            Regards.
            fernando padão
            arquiteto
