    Is there a minimum rotation for components?
    5 Posts 3 Posters 1.2k Views 3 Watching
    • Al HartA Offline
      Al Hart
      I seem to be able to place a 0.06 rotation on a component, but not a 0.05 rotation.
      Here is the code setting the transform on the component:
      			trace("ROTATE angle; %g in rad; %g",angle, deg2rad(angle))
      			trot = Geom;;Transformation.rotation(center, axis_vector,  deg2rad(angle.to_f))
      			show_transformation("TROT",trot)
      			component.transformation = trot
      			tmid = component.transformation
      			show_transformation("TMID",tmid)
      Here is the output for a 0.05 rotation angle. The transformation does not seem to be applied to the component.
      ROTATE angle; -0.05 in rad; -0.000872665
      TROT
      	1 -0.0008727 0 0
      	0.0008727 1 0 0
      	0 0 1 0
      	0 0 0 1
      TMID
      	1 0 0 0
      	0 1 0 0
      	0 0 1 0
      	0 0 0 1
      Here is the output for a 0.06 rotation angle. It is applied properly.
      ROTATE angle; -0.06 in rad; -0.0010472
      TROT
      	1 -0.001047 0 0
      	0.001047 1 0 0
      	0 0 1 0
      	0 0 0 1
      TMID
      	1 -0.001047 0 0
      	0.001047 1 0 0
      	0 0 1 0
      	0 0 0 1
      TMID is the rotation on the component after applying TROT.
      0.06 works ok, but 0.05 does not seem to take.
      has anyone run into a similar problem?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • KrisidiousK Offline
        Krisidious
        is this a rhetorical question? cuz you seem to know the answer...
        By: Kristoff Rand
        • Al HartA Offline
          Al Hart
          I tried it in two places, but perhaps another Ruby programmer has found a way to solve it.
          For example, I am trying to apply a 0.05 rotation to the current rotation. Perhaps there is another way to do this.
          Also, I have not done a test to see if all component rotations are rounded off (or just very small ones). For example, I could try rotations of 10.05 and 10.06 degrees and see if they give the same result.
          In my other CAD systems (we are the developer for ARRIS CAD), this would be a problem, because if you had a very large component and rotated it, and the rotation was rounded off, and then you measured something it could be off by several feet.
          Al Hart
            RickW
            It is far less than ideal, but did you try over-rotating and then rotating back slightly less? ie. rotate 4 degrees, then come back 3.95 degrees (or radians, or whatever units)
            I suspect, though, that you're running into Sketchup's tolerance settings. No evidence other than your own - just a hunch.
            RickW
            www.smustard.com
              Krisidious
              nice thinking outside the box or radian as it were... Rick
              By: Kristoff Rand
