    Animation problem...
    3 Posts 3 Posters 997 Views 3 Watching
      matt4
      I'm working on an model that I want to create an animation with. When I setup the scenes the picture looks perfect. When I create the animation it crops the animation from the sides and I loose part of the picture. I set the picture size to 1200x900 and I thought it was big enough but apparently I was wrong. Could anyone offer me any suggestions to correcting this problem.
      Thanks ahead of time.
      • O Offline
        otb designworks
        If your monitor size allows for a working window that is larger than 1200 x 900, then you will get some cropping on the sides.
        A trick I use often is set my scenes with a pretty small window and then I know nothing will get cropped when I export at a larger size.
        You can also export a 2d image and set the size to what you are going to want to export the animation (1200 x 900). open this still image in an image viewer, choose to display at actual size, and use this window to size you SU working window (when in doubt, make the SU window a bit smaller than the image) and you should be good to go.
        Cheers, Chuck
        OTB Designworks is on Youtube
          mirjman
          to size the window proportions right for any exporting, i usually go to the export jpeg options menu, set the desired width, then keep resizing your sketchup window until the desired depth appears (guess and check style). Very annoying! anyone have a work around?
          kannonbal, your trick is pretty good πŸ˜ƒ but still doesn't let you set the window to the exact proportion you need. It would be nice if you could do it all in sketchup.
