    Primary Pouf - DWR
    12 Posts 5 Posters 2.7k Views 5 Watching
      cheffey
      This is the Primary Pouf - seating & side table rolled into one. Designed by Arne Quinze. I've made a skippy with one of each color option in there & I'll create a zip file with them separated individually.
      Real Thing: http://www.dwr.com/productdetail.cfm?id=7358
      primary pouf-all.skp
      BROS RŌMAN BRÄUN
        cheffey
        Attached is the zip file were it's one skippy per Pouf.
        PrimaryPouf-swb.zip
        BROS RŌMAN BRÄUN
          cheffey
          Here is a sketchup view.
          BROS RŌMAN BRÄUN
            cheffey
            obligatory render 😆
            BROS RŌMAN BRÄUN
            • boofredlayB Offline
              boofredlay
              The Pouf's are nothing without the girl... Post The Girl Man!
              • jujuJ Offline
                juju
                😆 HEAR HEAR! You know what to do cheffrey! 😉
                  lewiswadsworth
                  If you like her, you should hang out in Second Life sometime. Most female avatars there seem to look like that..do you know that there are whole websites devoted to avatar pinups?...where you can decide if a given Barbie-doll avatar is "hot or not."
                  No, I won't give you a direct link. You have more constructive things to do with your time.
                  poster-Lewis Wadsworth
                  col sporcar si trova
                    boofredlay
                    Yes, I have more constructive things to do... (looks off to the distance)
                      cheffey
                      wow, it's great to see so much pouf positivity. better get these poufs, cause they are popular with the ladies...
                      BROS RŌMAN BRÄUN
                        lewiswadsworth
                        Cheffey,
                        All right, I have to ask: where are the overly-developed female figures from? Are you making them yourself in Poser or is there some depository out there, a Google Warehouse for the prurient, where you can download babes?
                        --Lewis
                          Lewis, you cannot download them - just hire them (even from the depository).
                          That's the rule man!
                            cheffey
                            Gaieus is right!
                            It's DAZ 3d models, pretty simple software to use.
                            I don't bring them into sketchup, just use them in different rendering software.
                            There is a lot of tutorial stuff out there for DAZ, the models are just too high poly for sketchup. Also, the faces still look very stoic, so i avoid a direct view.
                            http://www.daz3d.com/
                            BROS RŌMAN BRÄUN
