    [Plugin] SectionCutFace v2.0
    65 Posts 23 Posters 74.2k Views 23 Watching
    • TIGT
      SectionCutFace.rb v2.0: update fixes an occasional visibility glitch with the cut-face's location relative to the section-plane, and layers are now sorted below the layers 'CUT-nnnn' and 'Layer0' (or the default layer-name if not EN).
      There is a new version available here http://forums.sketchucation.com/viewtopic.php?p=172583#p172583
      please use that instead of the obsolete one below
      Obsolete...[attachment=0:2kwr50ms]<!-- ia0 -->OLD-SectionCutFace.rb<!-- ia0 -->[/attachment:2kwr50ms]PayPalButton
      SectionCutFace.rb
      • GaieusG
        Thanks TIG, very much, indeed! I've been using the script a lot and I can tell the only thing that bothered me was what you've fixed now (mainly when I used a lot of components/groups especiall when nested ones, and a lot of layers etc...)
        Works like a charm now - beautiful!
        Thanks again...
        • O
          otb designworks
          Thanks TIG, this is a great Ruby and I use it a bunch.
          Cheers, Chuck
          OTB Designworks is on Youtube
          • R
            richcat
            Thanks TIG
            This will come in handy πŸ˜„
            • D
              dylan
              Thanks TIG, great Ruby.
              http://dmdarchitecture.co.uk/
              • boofredlayB
                boofredlay
                That is a nice one. I have used it for quite a while but the newer version is so much easier. The old one I always had to back the section cut up a small amount just to see it.
                Thanks again.
                • S
                  sorgesu
                  I took a look see and I have a couple of problems with the script.
                  The colours list stops at the bottom of the page ending with the "L" colours and there is no way to scroll down to choose anything else. If I wanted a "White" face colour I could type "W" in the face colour field but then I would have to settle for "Wheat" because that is the first "W" and I can't get at the rest. The Cut face colour actually allows for the "Default" colour but the cut edge colour does not.
                  Susan Sorger
                  • GaieusG
                    That's true, Susan but don't forget that you can repaint the faces of the group any time (even with custom colours/textures for the different parts of the building).
                    My glitch was however that it did not seem to work within a group. I wanted to place a section cut into the ground only (which I had grouped) to show the building's underground parts from the side and it was just simply not there.
                    • S
                      sorgesu
                      I can't make this work. I viewed hidden geometry, I moved the section plane a tad, and I see no surface at all in the section.
                      I also exported the section and viewed in a free cad viewer and there is no face. What am I doing wrong?
                      Susan Sorger
                      • GaieusG
                        Right click on the active section plane and there is a menu item "add section cut face" (though you must have done this).
                        Then it just appears.
                        Have a look at some of the section cuts here (textured by the surrounding material though):
                        http://www.gaieus.hu/EM
                        • S
                          sorgesu
                          Well, yes I have done this. I read all of the notes in the script.
                          I even exploded all of the parts of the model that were grouped just in case that was the problem. Nothing helps.
                          Won't create a face. The layer is there, but there is nothing on it.
                          This is an old model but it has been brought into SketchUp 6 and so I can't figure out what the problem could be.
                          Susan Sorger
                          • GaieusG
                            You'll need to get TIG for this then.
                            Can you pass the model somehow?
                            • S
                              sorgesu
                              I'll take a look. It's really big so I'm not quite sure how to do it. I think I can put it on Kelly's ftp.
                              I tried it with another model that was originally a version 5. With this one it created a face , partally. On of the components that was part of the cut, had a face, and a small enclosed piece of geometry had a face. The rest was empty space. I figured it might have something to do withe the space which was around a component so I exploded everything completely and tried again. The result was the same. The same things had faces and the same things didn't though it was all completely exploeded at this point.
                              I'll see about getting these models up.
                              Susan Sorger
                              • S
                                sorgesu
                                Okay, I have 2 models with the Section Cut face in them that are not working correctly. They are both in this folder on Kelly's site:
                                http://www.sketchucation.com/forums/scf/sas/Ruby/SectionFaceProb
                                Susan Sorger
                                • GaieusG
                                  Susan,
                                  I opened the file "treasury2" and the section cut was there as it was supposed to be. See attached image.
                                  • S
                                    sorgesu
                                    but there is space all around the doorway. Why is there no face in that space?
                                    I thought the script fills in a face everywhere
                                    Susan Sorger
                                    • GaieusG
                                      You're right - it should fill that face, too - unless it is intelligent enough to know that that's the inside room of the building and does not need to fill it with a face. I'll go into it, I think.
                                      • TIGT
                                        Press W to drop to Wheat then use the down arrow key to get to White...
                                        • S
                                          sorgesu
                                          ahh thanks, down arrow within window, not in drop down list. Go it.
                                          Now about the faces??
                                          Susan Sorger
                                          • TIGT
                                            The script attempts to work out what is solid and what is void, so it doesn't (usually) fill in every available gap. To see this draw a rectangle and offset it and pushpull it into a 'wall', reface the top and pushpull to make a quick floor and a roof; then draw a rectangle onto a wall face and pushpull it through the wall to make an opening. Now make a section cut across the wall passing through the window 'hole'. Use SectionCutFace on it and you'll get a filled-in section as you expect. But if you put a face or faces into the window as a 'pane' it can get confused as to which is solid and which is void in the cut. Usually if fills them all and you can then edit the section face group and select and delete unwanted faces, or redraw edges to (re)face something that's missed... Overlapping solids can confuse it as there's no simple rules to work out what's desired to be solid - typically the outer areas get filled, then any inner islands are emptied, then any nested islands filled etc (like CAD hatching ?)...
                                            It's not foolproof...you should be able to make quick manual fixes to complex sections that get confused.
                                            • 1 / 4
