    Snaps
    15 Posts 6 Posters 7.9k Views 6 Watching
    • P Offline
      perk
      Is there a way to force a snap? I have an object that I would like to extend but because it is not square or perpendicular to it other edged push/pull doesnt work as it wiil alter the shape I am going for. I would simply like to extend the line but since it is close to the green axis (or any other axis in other cases) I keep getting the green axis snap. I dont want to keep rotating my model to do it since I have multiple instances of this. Sometimes I can get the pink extention snap but other times it just doesnt want to do it. Is there a simple comand that would do such as locking on the red green or blue axis?
        Marek Badzynski
        Perk,
        try using the arrow buttons, or hold down the Shift key while you are parallel to a blue/red/green axis (and move mouse again)
        HTH,
        Marek
        • Jean LemireJ Offline
          Jean Lemire
          Hi folks.
          As soon as you have the magenta or pink inference, press and hold the SHIFT key to lock it. Then you can lengthen the line.
          Just ideas.
          • P Offline
            perk
            The thing is I DONT want the red, bule or green axis. I want the magent (extention) but I am having trouble getting it because the green axis seems to be overiding it due to it's close proximity. I was hoping to force it in the same way that you can force the red, green or blue by using the arrow keys.
              Masta Squidge
              What if you just rotate the whole model like... 10 degrees.
              Then the lines wont be so close to one axis or another. And if it HAS to be oriented in that direction, you can just rotate it back the same 10 degrees once finished.
              • Chris FullmerC Offline
                Generally you don't have to actually rotate the model 10 degrees, just rotate the view. I agree that snaps can often be too sticky to more "powerful" snaps though. I find I need the black snap often, buts its always over-ridden by red or green.
                All my Plugins I've written
                • P Offline
                  perk
                  Chris
                  I'm not sure what the black snap is
                  Maybe this should be in the wish list. A simple single keystroke that will force the perpendicular or extention snap.
                    The black snap is the intersection snap. Draw a rectangle and both diagonals. Where they cross each other, you will find a black snap.
                    • P Offline
                      perk
                      Sorry I knew that. I guess I wasn't thinking. It's still early. Ihaven't had my coffee yet.
                        I think the workaround is to change the axes temporarily to be out of way and at the end just right click and choose "restore".
                        It will however restore the very original global axes so if you are working with already changed ones and want to reasore those, this wouldn't be good (or you can do it manually)
                          Jean Lemire
                          Hi folks.
                          See attached SU file for ideas.
                          Forcing snaps.skp
                          • P Offline
                            perk
                            Jean
                            I have two questions about your tut.
                            1. How did you get the construction line colinear w AC in scene 2?
                            2. Hoe did you get the inference colinear with line AC in scene 4?
                            • P Offline
                              perk
                              I ran into a problem I posted in a different topic before. As I was replying to Jeans tut when I hit the submit button this text box went blank and nothing posted. I had to retype it. I have had this problem several times in the past. I dont know if it is my computor or if it is something withthe site. It only seams to happen on my work computer and not from home or school. It also seams to be only when I type several lines. If I keep it short it doesnt happen. Just wanted to let you know.
                                Perk,
                                1. when you start a construction line other than from the endpoint on an edge and you move along the edge itself, it will always be colinear.
                                2. start drawing from the endpoint and hover along the edge you want to make longer. When it say "on edge", press the shift key and you are locked in that line. Now you can move it into the other direction.
                                As for your other post - are you also logged out at these times? Is it not possible that someone posted right while you were typing and the system only "offers" a post review?
                                Are cookies from scf allowed on this machine of yours?
                                • P Offline
                                  perk
                                  Gaieus, Jean
                                  I got it to work. Thanks for your help.
