    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    Pantone colors library
    38 Posts 17 Posters 24.6k Views 17 Watching
      Well, as I said, I went to see all permissions (I can even "test" anyones permissions like as if I were him/her) but I could see the PM button (even went into the PM area).
      I went to the admin panel and nothing special.
      Anyway, there is no option to hide the PM button for/from specific users anyway.
      I am really sorry, I don't know what else I could do.
        todamgood4U
        That's really odd...but then again, not suprising with the way things usually go for me. I always say, if it weren't for bad luck, I'd have no luck at all.
        But I know I'm not that stupid...see...
          Well, maybe Didier has put you onto his foe list!
          πŸ˜„
            todamgood4U
            I thought of that, but I went through the first 10 pages or so of members and Stu is also unavailable and a couple others. I never PM, so I'm not too concerned, but it is odd since no one else has the problem.
              Or at least no-one has reported it yet.
              On the other hand, if you were a foe to him, he could not even see your posts (would totally ignore you) and apparently not this is the case.
              • Didier BurD Offline
                Didier Bur
                What for ? 8O
                No way.
                DB
                • Paul RussamP Offline
                  Paul Russam
                  Just reading this topic and I to get no PM button for Didier, I checked the Member List like Todum did and both Didier and Stu's PM buttons are absent.
                  Here's a list of who's PM button is missing (for me)
                  47 Didier Bur
                  59 Stu Mayhew
                  191 trufel
                  402 tuzzi2
                  578 spire7k
                  719 diana
                  1224 Nicole
                  1260 2mv
                  1565 sparky4945
                  Paul Russam
                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                    Didier Bur
                    It should be present now. Sorry, my profile was not set correctly 😳
                    DB
                      todamgood4U
                      Ah yes...much better. Did you get those ACO files I sent the other day? If so, do you think they will be of use?
                        Paul Russam
                        Didier,
                        Yep that did it.
                        Paul Russam
                          Paul, you rule!
                          Thanks a lot!
                          I have checked some of these people's preference settings and they say "members cannot send PM".
                          Well, that's their choice(and when one signs up to a "new" forum, tries to be "cautious" too) so this might be the case - they just "left it like that".
                          There is an option here (for admins) to "try a user's permissions" - and both Coen and I did it (as posted above) with todamgood4U but it seems that it only applies to "general" board, moderators or admins permissions and as I checked, I could see Didier.
                          Anyway, the problem seems to have been solved so thank you again!
                            Didier Bur
                            Hi todamgood4U,
                            Yes I got them.
                            As soon as I've debugged an ACO C++ reader that converts swatches files to hexa colors, I'll be able to generate the library (I can read the colors by now, but there's a bug to read their names).
                            Regards,
                            DB
                            • utilerU Offline
                              utiler
                              thanks for the zips, Paul. is there any reason why they take so long to extract? they seem only small files.....
                              Andrew
                                Debecorator
                                I seem to recall browsing a message here that said if the files for Moore colours were available in any format, we could get help getting them into an importable format for Sketchup?
                                On http://www.bejaminmoore.com in the designers section, the palettes are offered in different formats including .acb for AutoCad, .aco for Photoshop and a zipped file for Lightworks.
                                I am a working designer and I use exclusively Moore and C2(readily available in .jpg) colours so it would be FABULOUS to be able to import Moore.
                                Thanks for any help you can give us Moore needers.
                                Deb
                                  Debecorator
                                  LINK DELETED<<
                                  this is for a website I stumbled accross on the Benjamin Moore site called Tectonic Studio. It has .jpg's for the whole Moore collection enlargeable and saveable and it offers other products too such as flooring and carpet - you can also order physical samples from the site.
                                  Deb
                                  MODERATOR EDIT: The deleted link connected to a website whose security certificate had expired or was not yet valid.
                                  The IE7 warning message read:
                                  "Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
                                  We recommend that you close this webpage and do not continue to this website."
                                    Mr.Slank
                                    Many Thanks Didier. 😍
                                      bilou69
                                      Many thanks. Will be really useful !
                                      • P Offline
                                        poxod
                                        Thank you- this is very useful! I was going to do this myself but Sketchup only allows you to add materials to a collection one at a time!
                                        • 2 / 2
