    Pantone colors library
    38 Posts 17 Posters 28.1k Views 17 Watching
    • boofredlayB
      boofredlay
      I just sent Didier a PM. Worked fine.
      Did you get it Didier?
      Thanks.
      • T
        todamgood4U
        No, I can not PM him. Looking at the posts above, everyone has a small PM button below their post, except Didiers post. That is why last night I went looking through the member list. I thought maybe I could PM him by adding as a friend, but to no avail.
        • boofredlayB
          boofredlay
          Well this is strange. Didier got my PM just fine.
          Gai... any thoughts? Coen?
          • GaieusG
            Well, as I said, I went to see all permissions (I can even "test" anyones permissions like as if I were him/her) but I could see the PM button (even went into the PM area).
            I went to the admin panel and nothing special.
            Anyway, there is no option to hide the PM button for/from specific users anyway.
            I am really sorry, I don't know what else I could do.
            • T
              todamgood4U
              That's really odd...but then again, not suprising with the way things usually go for me. I always say, if it weren't for bad luck, I'd have no luck at all.
              But I know I'm not that stupid...see...
              • GaieusG
                Well, maybe Didier has put you onto his foe list!
                πŸ˜„
                • T
                  todamgood4U
                  I thought of that, but I went through the first 10 pages or so of members and Stu is also unavailable and a couple others. I never PM, so I'm not too concerned, but it is odd since no one else has the problem.
                  • GaieusG
                    Or at least no-one has reported it yet.
                    On the other hand, if you were a foe to him, he could not even see your posts (would totally ignore you) and apparently not this is the case.
                    • Didier BurD
                      Didier Bur
                      What for ? 8O
                      No way.
                      DB
                      • Paul RussamP
                        Paul Russam
                        Just reading this topic and I to get no PM button for Didier, I checked the Member List like Todum did and both Didier and Stu's PM buttons are absent.
                        Here's a list of who's PM button is missing (for me)
                        47 Didier Bur
                        59 Stu Mayhew
                        191 trufel
                        402 tuzzi2
                        578 spire7k
                        719 diana
                        1224 Nicole
                        1260 2mv
                        1565 sparky4945
                        Paul Russam
                        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                        • Didier BurD
                          Didier Bur
                          It should be present now. Sorry, my profile was not set correctly 😳
                          DB
                          • T
                            todamgood4U
                            Ah yes...much better. Did you get those ACO files I sent the other day? If so, do you think they will be of use?
                            • Paul RussamP
                              Paul Russam
                              Didier,
                              Yep that did it.
                              Paul Russam
                              • GaieusG
                                Paul, you rule!
                                Thanks a lot!
                                I have checked some of these people's preference settings and they say "members cannot send PM".
                                Well, that's their choice(and when one signs up to a "new" forum, tries to be "cautious" too) so this might be the case - they just "left it like that".
                                There is an option here (for admins) to "try a user's permissions" - and both Coen and I did it (as posted above) with todamgood4U but it seems that it only applies to "general" board, moderators or admins permissions and as I checked, I could see Didier.
                                Anyway, the problem seems to have been solved so thank you again!
                                • Didier BurD
                                  Didier Bur
                                  Hi todamgood4U,
                                  Yes I got them.
                                  As soon as I've debugged an ACO C++ reader that converts swatches files to hexa colors, I'll be able to generate the library (I can read the colors by now, but there's a bug to read their names).
                                  Regards,
                                  DB
                                  • utilerU
                                    utiler
                                    thanks for the zips, Paul. is there any reason why they take so long to extract? they seem only small files.....
                                    Andrew
                                    Just Curious...
                                      Debecorator
                                      I seem to recall browsing a message here that said if the files for Moore colours were available in any format, we could get help getting them into an importable format for Sketchup?
                                      On http://www.bejaminmoore.com in the designers section, the palettes are offered in different formats including .acb for AutoCad, .aco for Photoshop and a zipped file for Lightworks.
                                      I am a working designer and I use exclusively Moore and C2(readily available in .jpg) colours so it would be FABULOUS to be able to import Moore.
                                      Thanks for any help you can give us Moore needers.
                                      Deb
                                        Debecorator
                                        LINK DELETED<<
                                        this is for a website I stumbled accross on the Benjamin Moore site called Tectonic Studio. It has .jpg's for the whole Moore collection enlargeable and saveable and it offers other products too such as flooring and carpet - you can also order physical samples from the site.
                                        Deb
                                        MODERATOR EDIT: The deleted link connected to a website whose security certificate had expired or was not yet valid.
                                        The IE7 warning message read:
                                        "Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
                                        We recommend that you close this webpage and do not continue to this website."
                                          Mr.Slank
                                          Many Thanks Didier. 😍
                                          • B
                                            bilou69
                                            Many thanks. Will be really useful !
                                            • 2 / 2
