    VRay Tests
    14 Posts 10 Posters 2.9k Views 10 Watching
    • S
      stuartb
      hope I am posting this is in the right place Juju . . .
      PS the forum message says "cannot add another . . 3 is the maxmimum" . . . should be 'maximum'
      http://www.sketchucation.com/forums/scf/sas/Gallery/01.jpg
      http://www.sketchucation.com/forums/scf/sas/Gallery/21.jpg
      http://www.sketchucation.com/forums/scf/sas/Gallery/24.jpg
      • S
        stuartb
        more . . .
        http://www.sketchucation.com/forums/scf/sas/Gallery/34.jpg
        http://www.sketchucation.com/forums/scf/sas/Gallery/31.jpg
        http://www.sketchucation.com/forums/scf/sas/Gallery/26.jpg
        • S
          stuartb
          last 2 . . . (is there a better way of doing this? . .adding messages?)
          http://www.sketchucation.com/forums/scf/sas/Gallery/37.jpg
          http://www.sketchucation.com/forums/scf/sas/Gallery/35.jpg
          • jujuJ
            juju
            Some good renders there Stuart!
            • J
              jeff jacobs
              Stuart,
              Tells us some more about these. What's the process and the setup time? They are nice renders. The only problem you are having is the same problem I have with my other render softwares–low poly count especially around the curved edges. Also, when exporting the triangulation is a killer in regards to file size and geometry structure. Almost impossible in other applications without a LOT of handwork. The lighting looks good.
              • M
                Mr S
                Just got round to viewing these images.
                Looking good.
                Can you supply any info/guides as to the settings you used?
                I really need to understand how to use this software.
                Mr S
                • KrisidiousK
                  Krisidious
                  wow... so detailed and so well lit...
                  By: Kristoff Rand
                  • D
                    dylan
                    These look good, a shame about the curved edge of the bath though.
                    http://dmdarchitecture.co.uk/
                    • N
                      not registered yet
                      with the bathtub, you can probably reconstruct it using a polygon with a higher number of polygons rather than using a circle or an arc. if you're taking this into max, you can use the smooth modifier.
                      as a personal preference, i would change the renderings into 2 point perspectives rather than 3 point perspectives.
                      P: wadefuh
                      • K
                        kwistenbiebel
                        I agree. A plain 2 point perspective will be much better!
                        (as a note, i like these images already 😉 ).
                        Also, the burnt areas around 'omnilights' are quite disturbing.
                        Very good renderings all together.
                        Cheers and keep'em coming 😉
                        • jenujacobJ
                          jenujacob
                          is it possible to render in 2 point perspective in vray?? 😲
                          • K
                            kwistenbiebel
                            Whenever your walls are vertical you have a 2 point perspective.
                            I know Sketchup has a seperate 2 point perspective option, but you can achieve an 'almost' 2 point persp. by just adjusting your viewport so the walls are vertically alligned.
                            For wide angle camera settings this sometimes is harder to achieve.
                            • jenujacobJ
                              jenujacob
                              ah like that... yea.. thats possible.. but still it would have been cool if we could render using SU's 2 point perspective.... 💚
                              • S
                                sepo
                                Actually is it possible to render 2 point perspective as such. Also is it possible to render elevations. I know it is not possible to render SU section.
