    Lines Won't Delete
    1 Posts 1 Posters 7.8k Views 1 Watching
    • ToboboT
      Tobobo
      I'm creating a seating component to use (and share) but there is some issue with deleting lines. When I delete one of the lines that aren't required, it becomes a profile thickness line and won’t delete unless I delete the face it is on and then it will delete.
      There are three components in it as it is a wooden seat with cham corners but it happens on most if not most of the lines!
      It’s getting frustrating and I would like to know if it happens on your machines as well.
      PS I have solved the problem (Thanks to Jackson) but it could be a bug that needs sorting.
      Type 5.skp
      Toby
      Philippians 4:13
