    Simple problems
    extensions
    3 Posts 2 Posters 1.3k Views 2 Watching
    • D
      deano40
      Hello, I'm really loving this plugin, but I'm having some problems. Starting with the basics, I'm trying to make a simple catapult. When I try to place two hinges on one object(the board) and attach another object (the weight) to one of the hinges it doesn't work. I know it must be simple because of all the great examples in the warehouse.
      Thanks for your time Deano
      and are there any other tutorials out there πŸ˜’
      P: deano40
      • J
        Jackson
        Deano,
        Are you holding down the Ctrl key while using the Joint Connector to join the weight and hinge? It took me a while to work that out- it's not very clear in the instructions. Hold down the Shift key to disconnect.
        Jackson
        • D
          deano40
          Jackson thanks for your reply, I think I finally have it. I wasn't grouping correctly, that was throwing me off.
          Thanks again, Deano
          P: deano40
