    FredoSection + LOTT freezes 'Scene Selector'.
    3 Posts 2 Posters 238 Views 2 Watching
      tsur
      Re: [Plugin] FredoSection - v1.5a - 15 Jan 26
      Thank you for releasing this highly anticipated extension.
      I’ve encountered an issue where using FredoSection via LOTT (LordOfTheToolbars) causes its 'Scene Selector' to freeze SketchUp (followed by 'Force Quit').
      When used with the standard Tool-Palette, all works fine.
      (SketchUp 26.1.184 / FredoSection 1.5a / macOS 26.2 / MacBook M1 Max).
      I’ve attached a screen-grab of the freeze.
      FredoSection_freeze.mp4
      • fredo6F Offline
        fredo6
        That's a bug with modal dialog boxes on Mac when you call them from another dialog. This has never been fixed in 10 years or more.
        It should work if you call the N dialog from the toolbar.
        I will fix that.
          tsur
          Thanks for your prompt and clear reply.
          Until the fix is in place, I’ll use it from the tool palette.
