    Adjusting Textures on a Diamond shaped Surface
    5 Posts 2 Posters 831 Views 2 Watching
    • R
      Robert
      Long time lurker here ๐Ÿ™‚
      Hoping I'm missing the obvious.
      I have a facade with diamond shaped cedar shingles modeled.
      I want to paint and manually move the texture around on each shingle.
      Typically I would right click and adjust the texture. Doesn't appear to work on these diamond shapes.
      Tried thru paint and quad tools with no solution.
      Any ideas?
      tuna1957T 1 Reply Last reply
      • tuna1957T
        tuna1957 @Robert
        @Robert Taking a w.a.g. without actually seeing the model. This usually is the result from painting the texture on a group/component without opening it for editing.
        • R
          Robert
          the diamond faรงade is a component and the geometry is painted in the component.
          I've uploaded the component here if you care to take a look.
          My plan was create a new texture but larger scale and move it around to fit on individual diamond shingles. to avoid the horizontal and vertical lines.
          https://www.dropbox.com/scl/fo/3ron3i66jhebaiyjj55h7/AE5zpEX7JBhDq5UFZtJhkuc?rlkey=98mff0zb8uz3ncezxkj57pr7u&dl=0
          • R
            Robert
            Upon further review it appears the geometry was softened and that was causing the issue.
            • tuna1957T
              tuna1957 @Robert
              @Robert Glad you got it sorted. ๐Ÿ‘
