can you update it like this?
Re: [Plugin] Recall last tool v1.2
code_text module Matt class MattObserver < Sketchup::ToolsObserver @@last_tool_id = nil @@toggle = true # Variable to control toggling def onActiveToolChanged(tools, tool_name, tool_id) # Save the tool ID if it’s not one of the excluded IDs @@last_tool_id = tool_id unless [21022, 10508].include?(tool_id) || tool_id >= 50000 puts "Active tool: #{tool_name} --> ID: #{tool_id}" unless [21022, 10508].include?(tool_id) || tool_id >= 50000 end def self.recall_last # Get the ID of the currently active tool active_tool = Sketchup.active_model.tools.active_tool_id # If the active tool is the selection tool and there's no other active tool, switch to the last tool if [0, 21022].include?(active_tool) if @@last_tool_id Sketchup.send_action(@@last_tool_id) else puts "No previous tool. Selecting default tool." Sketchup.send_action("selectSelectionTool:") end else # If another tool is active, switch to the selection tool Sketchup.send_action("selectSelectionTool:") end end end # Add the observer to SketchUp's tools Sketchup.active_model.tools.add_observer(MattObserver.new) # Add "ReCall" menu item unless file_loaded?(__FILE__) menu = UI.menu("Plugins") # Adds item under the "Plugins" menu menu.add_item("ReCall") { MattObserver.recall_last # Calls the recall_last method when clicked } file_loaded(__FILE__) end end
Register LoginAdvertisement
