    Sketchucation 4.4.1 Error
    1 Posts 1 Posters 62 Views 1 Watching
    • F Offline
      Finito86 Newcomers
      Hello everyone!
      I've installed the sketchucation but i cant make it show up. At the start up of sketch Up it says this error was found.
      Informe de errores de extensión
      SketchUp: 24.0.553
      OS: Windows 11
      Ruby: 3.2.2
      Extensión: SketchUcation (4.4.1)
      Error: Failed to load file (Failed to read RBE/RBS file.)
      H:/Sketch Up/Tools/extensions.rb:197:in load' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:181:in register_extension'
      C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:181:in <module:SCF>' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:17:in <top (required)>'
      Same problem accurs with several extensions like Fredo6, localise, Dinamic Components and the Sandbox tool. Witch by the way i did not installed but it comes with sketch up 24. Still showing errors. I paste the DInamic Components Error to show you.
      SketchUp: 24.0.553
      OS: Windows 11
      Ruby: 3.2.2
      Extensión: Componentes dinámicos (1.8.3)
      H:/Sketch Up/Tools/extensions.rb:197:in load' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_dynamiccomponents.rb:54:in register_extension'
      C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_dynamiccomponents.rb:54:in `<top (required)>'
