    Can't uninstall Sketchup 2023
    Scheduled Pinned Locked Moved Solved Newbie Forum
    2 Posts 2 Posters 814 Views 2 Watching
    • zain01Z
      zain01
      My colleague has downloaded Sketchup 2024 and now can't seem to uninstall Sketchup 2023. It doesn't show up in the installed apps page or via control panel. Even our IT dept couldn't seem to locate it and just referred us to the Sketchup help page
      Uninstalling SketchUp
      WindowsQuit all open instances of SketchUp.Click the Start menu.Click Settings or search for Apps using the search bar.Locate SketchUp from the list of installed appsClick the context menu (...) and select Uninstall.Tip: If you are having problems with SketchUp, try the Modify option, which verifies the current installation and will repair any errors in the current installation.Mac OS XQuit all open instances of SketchUp.Open a Finder
      (help.sketchup.com)
      However when following this guide you get to step two & cannot continue as Sketchup 2023 isn't in the list.
      Let me know if you have any ideas as its annoying not having Sketchup2024 as default
      Thanks in advance.
      Z
      • F
        FlawinneF
        No on my Windows 11 laptop the 2 entries are present.
        If an application is not visible in the list of applications, it could be for several reasons, what I would do first is check in the registry if the entry in "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall ", once you do a search on "SketchUp 2023"
        which for my part with the latest version gives the following result "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6af6b504-1cb0-504c-f20f-061179014e6d}"
        If you find that without any approach, look at the line named UninstallString and take the value MsiExec.exe /I{6af6b504-1cb0-504c-f20f-061179014e6d}. in my case.
        Executing this command starts the sketchup setup.
        If you don't find anything, I would reinstall sketchup 2023, simpler than manual cleaning.
        There is another one for troubleshooting at Microsoft https://download.microsoft.com/download/7/E/9/7E9188C0-2511-4B01-8B4E-0A641EC2F600/MicrosoftProgram_Install_and_Uninstall.meta.diagcab
        But it is a tool that requires a certain amount of experience, so be careful, it is necessary to take some precaution, such as a backup system at least, see an image of the disk.
        • Rich O BrienR Rich O Brien marked this topic as a question on
