    Playing arround with Sketchup diffusion
    99 Posts 11 Posters 9.7k Views 11 Watching
    • jo-keJ Offline
      jo-ke
      quick tutorial to show how I use Sketchup Diffusion:
      At first look for a drawing of a building, then texture a cube with it, and set the view to front view. then start Sketchup Diffusion. I typed for promt: "fassade of an old building, dirty beige sandstone" and hit "generate".
      then I took the best one and hit "add scene". then I took the sketchup function "project texture" to exchange the drawing with the AI texture.
      the cube is textured
      some work on geometrie.... finished in less then 5 minutes....
      and a quick render in Twilight Render
      http://www.zz7.de
      • jo-keJ Offline
        jo-ke
        playing some more.
        again the 3D figures...
        su view
        sketchup diffusion to stablediffusion, lora and ReActor Faceswap
        not to bad
        http://www.zz7.de
        • jo-keJ Offline
          jo-ke
          new playing arround:
          at first I asked Midjourney to create a unique seamless texture for a modern building
          jo3d3_seamless_pattern_photorealistic_texture_of_a_modern_germa_749a0d27-4cc5-4394-9d11-f3d4c2e96615.png
          then I created a scene in SU and hit render in Sketchup diffusion.
          result was a nice AI render of the scene
          then I took the render to kreaAI and a little postpro in Photoshop
          http://www.zz7.de
          • jo-keJ Offline
            jo-ke
            but a solid render with twinmotion is still better!
            and retouched with KreaAI
            http://www.zz7.de
            • jo-keJ Offline
              jo-ke
              I am still trying to make the best out of sketchup diffusion.
              I hope they will develop it further....
              When merging su and su diffusion the result comes out quite nice....
              su view:
              su diffusion:
              merged them both in photoshop "hard light"
              background enhancment with kreaAI:
              http://www.zz7.de
              • jo-keJ Offline
                jo-ke
                just 5 clicks and 2 minutes work to produce a nightshot:
                http://www.zz7.de
                Rich O BrienR 1 Reply Last reply Reply Quote 2
                  Rich O Brien Moderator @jo-ke
                  @jo-ke I gotta admit I'm not a fan of AI. I know there's no escaping it. I just find it hard to say wow or well done.
                  I don't know what to say. Its a timesaver.
                  • jo-keJ Offline
                    jo-ke
                    new try.
                    I took a picture of my fathers car of the 60ties. and ran it through meshy.ai to get a sketchup- model of it.
                    then I rendered it with sketchup diffusion and modification in krea.ai, merged and little correction in Photoshop.
                    everything took less then 10 minutes.
                    http://www.zz7.de
                    Rich O BrienR 1 Reply Last reply Reply Quote 3
                      @jo-ke I never know what to say about AI images...
                      Its impressive at what it does.
                      • jo-keJ Offline
                        jo-ke
                        I am trying something new.
                        I tried to use chatGPT to render and it worked quite well.
                        I took a sketchup Image to chat GPT and used the promt: "render this base image without changing any detail or moving features etc. Ultra realistic with neutral light"
                        source:
                        result:
                        some minor issues but much better than Sketchup diffusion.
                        I hope Sketchup Diffsion will be develloped further
                        another one with a cabinet:
                        source:
                        result:
                        http://www.zz7.de
                        J 1 Reply Last reply Reply Quote 1
                        • jo-keJ Offline
                          jo-ke
                          another try with midjourney wasn't as good as ChatGPT
                          jo3d3_render_this_base_image_without_changing_any_detail_or_m_a40e8811-4de9-44db-bcf0-76ed8d455d51_0.png
                          to many changes in geometry. Still one of the main issues in AI.
                          this one was the best out of 12 results
                          http://www.zz7.de
                          • jo-keJ Offline
                            jo-ke
                            Grok wasn't able to change the style.
                            http://www.zz7.de
                              JGA @jo-ke
                              @jo-ke said in Playing arround with Sketchup diffusion:
                              The examples a bit of a revelation to me.
                              Thanks for sharing the prompt.
                              Regards,
                              JGA
                              • marked001M Offline
                                marked001
                                All of these train images are great. I really need to play around with this more. Thanks for sharing.
                                http://www.revision21vis.com
                                instagram: revi21on
                                • jo-keJ Offline
                                  jo-ke
                                  best result with Nano Banana:
                                  http://www.zz7.de
                                  • jo-keJ Offline
                                    jo-ke
                                    and this one:
                                    time to create: one Minute:
                                    http://www.zz7.de
                                      That nailed it. Did you prompt for the Palm Trees? I heard Nano Banana was pretty good. This has none of the issues your normally get with AI image generation. In particular the windows on buildings.
                                      • jo-keJ Offline
                                        jo-ke
                                        this AI is by far the best I've seen.
                                        this took me one minute:
                                        Promt:
                                        "turn this sketch of a tramway into a photorealistic atmosphearic image with natural light and reflections on surface, no outlines, tramway driving on rails in the city of Mannheim, sunny waeather, do not change geometrie of the tram"
                                        http://www.zz7.de
                                        • jo-keJ Offline
                                          jo-ke
                                          this is crazy:
                                          http://www.zz7.de
                                          • jo-keJ Offline
                                            jo-ke
                                            Sketchup diffusion seems to be so old fashioned. Google is the absolute winner!
                                            http://www.zz7.de
                                            • 4 / 5
