    Playing arround with Sketchup diffusion
    99 Posts 11 Posters 14.8k Views 11 Watching
    • Rich O BrienR Online
      Rich O Brien Moderator @jo-ke
      @jo-ke I gotta admit I'm not a fan of AI. I know there's no escaping it. I just find it hard to say wow or well done.
      I don't know what to say. Its a timesaver.
      • jo-keJ Offline
        jo-ke
        new try.
        I took a picture of my fathers car of the 60ties. and ran it through meshy.ai to get a sketchup- model of it.
        then I rendered it with sketchup diffusion and modification in krea.ai, merged and little correction in Photoshop.
        everything took less then 10 minutes.
        http://www.zz7.de
        Rich O BrienR 1 Reply Last reply Reply Quote 3
          @jo-ke I never know what to say about AI images...
          Its impressive at what it does.
          • jo-keJ Offline
            jo-ke
            I am trying something new.
            I tried to use chatGPT to render and it worked quite well.
            I took a sketchup Image to chat GPT and used the promt: "render this base image without changing any detail or moving features etc. Ultra realistic with neutral light"
            source:
            result:
            some minor issues but much better than Sketchup diffusion.
            I hope Sketchup Diffsion will be develloped further
            another one with a cabinet:
            source:
            result:
            http://www.zz7.de
            J 1 Reply Last reply Reply Quote 1
            • jo-keJ Offline
              jo-ke
              another try with midjourney wasn't as good as ChatGPT
              jo3d3_render_this_base_image_without_changing_any_detail_or_m_a40e8811-4de9-44db-bcf0-76ed8d455d51_0.png
              to many changes in geometry. Still one of the main issues in AI.
              this one was the best out of 12 results
              http://www.zz7.de
              • jo-keJ Offline
                jo-ke
                Grok wasn't able to change the style.
                http://www.zz7.de
                  JGA @jo-ke
                  @jo-ke said in Playing arround with Sketchup diffusion:
                  The examples a bit of a revelation to me.
                  Thanks for sharing the prompt.
                  Regards,
                  JGA
                  • marked001M Offline
                    marked001
                    All of these train images are great. I really need to play around with this more. Thanks for sharing.
                    http://www.revision21vis.com
                    instagram: revi21on
                    • jo-keJ Offline
                      jo-ke
                      best result with Nano Banana:
                      http://www.zz7.de
                      • jo-keJ Offline
                        jo-ke
                        and this one:
                        time to create: one Minute:
                        http://www.zz7.de
                          That nailed it. Did you prompt for the Palm Trees? I heard Nano Banana was pretty good. This has none of the issues your normally get with AI image generation. In particular the windows on buildings.
                          • jo-keJ Offline
                            jo-ke
                            this AI is by far the best I've seen.
                            this took me one minute:
                            Promt:
                            "turn this sketch of a tramway into a photorealistic atmosphearic image with natural light and reflections on surface, no outlines, tramway driving on rails in the city of Mannheim, sunny waeather, do not change geometrie of the tram"
                            http://www.zz7.de
                            • jo-keJ Offline
                              jo-ke
                              this is crazy:
                              http://www.zz7.de
                              • jo-keJ Offline
                                jo-ke
                                Sketchup diffusion seems to be so old fashioned. Google is the absolute winner!
                                http://www.zz7.de
                                  The rate of improvement is staggering. Would like to see the heat generated by the AI infrastructure utilised better.
                                  • jo-keJ Offline
                                    jo-ke
                                    I am trying the new version of sketchup diffusion
                                    what should I say. It is definitly not there, where it could be.
                                    I made a model of my house in SU:
                                    this is the result of the new Sketchup diffusion after 5 mintues:
                                    and this is the result in Nano Banana after 2 minutes:
                                    Nano Banano ist more acurat regarding geometrie , colors and details.
                                    http://www.zz7.de
                                    • jo-keJ Offline
                                      jo-ke
                                      adding grapes to the house in just 5 minutes in Nano Banana:
                                      and here are some real photos:
                                      http://www.zz7.de
                                        Did you see its not embedded in Photoshop. They did a really good integration.
                                        jo-keJ 1 Reply Last reply Reply Quote 1
                                        • jo-keJ Offline
                                          jo-ke @Rich O Brien
                                          @Rich-O-Brien I should upgrade my photoshop (still using 2024)
                                          http://www.zz7.de
                                          • jo-keJ Offline
                                            jo-ke
                                            here's a new test.
                                            SU Model: first render SU diffusion,
                                            enhancment with nano banana.
                                            video made with grok.
                                            render time for whole process pictures and video 5 minutes
                                            video:
                                            Make your own video with Grok Imagine
                                            Video generated by Grok.
                                            Grok (grok.com)
                                            http://www.zz7.de
                                            • 4 / 5
